Gauge Temp Limits?
Old May 4, 2009 | 01:09 AM
Motoxman_117's Avatar
Motoxman_117
Gauge Temp Limits?
I am getting ready to order either a water temp gauge or oil temp gauge but don`t know which one yet. What are the dangerous temp limits for engine oil and water temp in deg F? Any help would be appreciated.
Old May 4, 2009 | 01:15 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Bump for you Lee
Old May 4, 2009 | 02:55 AM
Quick444's Avatar
Quick444
Good question Lee, I was wondering the same and I already have the oil temp gauge. I seem to be in the 190-215 range when cruising.
Old May 4, 2009 | 05:40 AM
Motoxman_117
I don`t trust the stock ford water temp gauge at all so I would like to know what is safe and what temp should i start getting concerned enough to back off the throttle , especially on some of the hills towing my trailer to arizona, utah and nevada. Last year the gauge started to climb a little bit so i backed out of it some. It was around 115 outside and I was pushing my truck pretty hard towing my 30ft Raptor up the pass between Vegas and St George UT.
Old May 5, 2009 | 12:38 AM
Motoxman_117
Anyone have the proper temps?
Old May 5, 2009 | 07:45 AM
Ponyboychris's Avatar
Ponyboychris
I have an Autometer water temp gauge and it sits right at 195 degrees when empty or pulling. I think I saw 200 degrees once pulling a load over a very high steep mountain pass.
Old May 5, 2009 | 08:05 AM
HKusp's Avatar
HKusp
Well it depends on your thermostat for one thing as far as water temp goes. The newer thermostats are 203* units because the 7.3 works more efficiently when hot. I would think that anything above 215 is pushing it though. Straight water boils at 212 degrees, with coolant added, it goes up to 223 degrees with a 50/50 mix not counting pressure. Being under pressure raises the boiling point some more, but I wouldn't let it get any higher that 220 degrees.
Old May 5, 2009 | 10:33 AM
Ponyboychris
I'll add that these temps are with the stock t-stat not the 203 degree one.
Old May 5, 2009 | 07:53 PM
Motoxman_117
Thanks everyone, that sounds like a good starting point. I am using the stock thermostat and will be sticking with that. I know our engines were made to run better at a little higher temp but I would think that the higher temps would be harder on all the rubber items like seals and hoses, etc... I will use 215 as a cautionary reference temp and 220 as the back off point. If anyone else has some hard data for this it would be great also. I decided to go with the water temp gauge and got it from Clay so should be there when I get home the middle of May.
turbill
43
Jul 31, 2011 12:38 AM
06truck ED
Aug 25, 2010 07:39 PM
got2befast
Jul 17, 2010 07:10 AM
Nice Work Truck
Jul 28, 2008 11:23 PM
johnsjsj
Sep 18, 2007 10:07 PM
