V code spring swap trials
Old May 3, 2009 | 08:56 PM
shadows4's Avatar
shadows4
Well started my spring swap today. Worked about 3.5 hours on the passenger side. Almost back together. Its slow going by yourself. But I stopped because I think I found part of my wander problem. The dog bone bushings were shot. Haven't been able to find the replacement parts yet. Do know they are going to be 70-75 bucks each. Haven't pulled the drivers side dog bone off yet but just seems like if I change one side I should do both sides. Anyway I will find the parts in the morning and finish the swap. Can't wait to hook up the TT for a test pull with the new springs.
Old May 3, 2009 | 09:51 PM
Stewart_H's Avatar
Stewart_H
Post up the replacement part numbers and where you got them from (if they aren't Ford parts) when you get everything buttoned up.
This will be good info to add to the "wander compilation" thread.
Stewart
Old May 4, 2009 | 05:13 AM
YellowSled's Avatar
YellowSled
leaf bushings?
Old May 4, 2009 | 09:33 AM
cbradford's Avatar
cbradford
Originally Posted by YellowSled
leaf bushings?
shadow4 said "dog bone bushings" so I think he means sway bar links not leaf bushings.
Old May 4, 2009 | 09:36 AM
cbradford's Avatar
cbradford
Stewart
Good point on the part #'s as this issue has been coming up often.
Old May 4, 2009 | 06:04 PM
shadows4's Avatar
shadows4
Yahoo!!!! I'm done. Worked about 2hrs today. Finished up the passenger side then moved on to the drivers. Only took about 1.5 hrs on the drivers side. Ride is a little firmer but not intolerable. Took a short drive on the hwy and the wander seems to be gone. The true test will be next week when I hook up the TT. The dog bones are sway bar links. I ended up getting them from one of the local Ford dealers. This one deals only in trucks so almost always has what I need in stock. Part #s are 1C3Z-5K483-BA List price $69.98
1C3Z-5K483-BB List Price $76.65
I already have a Helwig sway bar and RAS system installed on the rear which had raised the rear about .75 inches. The springs raised the front about 1.5 inches so it sit about level now. So far I am satisfied with the results but will post again in this thread after I tow with it. Thanks to everyone who has ever posted directions to their install, they were invaluable. John
Old May 4, 2009 | 06:29 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by shadows4
Part #s are:
Good job!
Regarding the part numbers, which one is the right side and which one is the left side?
Stewart
Old May 4, 2009 | 08:41 PM
shadows4's Avatar
shadows4
Stewart, the BB, the more expensive one is the right hand side.
Old May 5, 2009 | 12:53 AM
Stewart_H's Avatar
Stewart_H
Excellent!
Ford part numbers for the sway bar end-link bushings are:
Left side: 1C3Z-5K483-BA (List price $69.98)
Right side: 1C3Z-5K483-BB (List Price $76.65)
Thanks.
Stewart
Old May 17, 2009 | 09:25 PM
shadows4's Avatar
shadows4
Just got back from camping this weekend. About a 200 mile round trip tow. Good news and kick myself in the butt news. First the good news is that the wander is much better. The kick myself news is that I had the tires rotated and balanced last week. Forgot they put the air pressure that Ford recommends in tires. 45psi in the front and 55 psi in the rear. I had been towing with 60 in the front and 70 in the rear. No wonder it felt wishy washy and still had some wander. I found the ticket for the rotation in the truck after I returned home. It is still better than it was and I am confident it will be all but gone when the tires are properly inflated. Unfortunately it will be several more weeks before I will have the opportunity to try.
Old May 17, 2009 | 09:42 PM
Stewart_H's Avatar
Stewart_H
Stewart
Old Dec 22, 2011 | 08:50 AM
dockrocker's Avatar
dockrocker
Excellent!
Thanks.
Stewart
Anyone use the Moog and/or Raybestos parts for this job? Rock Auto shows either of those to be about $20-25 cheaper per side. I'm all for saving some coin as long as I'm not shorting myself on the quality front.
Old Dec 22, 2011 | 11:39 AM
labman1014's Avatar
labman1014
I have the moog. If I had to do it again, I would get just the new bushings. The bolt on the moog is smaller than the hole in the frame and no matter how tight I get it, it will still pop on uneven turns.
alexk3303
May 2, 2016 11:26 PM
FlatBlak
Sep 6, 2014 03:06 PM
bigboisteiny
Jul 30, 2014 04:41 PM
speakerfritz
Jul 3, 2014 10:19 AM
teppler
Feb 19, 2010 11:08 AM
