Potential Method to Clear P1000 Code
Old May 3, 2009 | 06:00 AM
svt2205's Avatar
svt2205
While searching for ways to evaluate the EVAP system on my truck (I have a gas smell in my cab), I ran into this. Ford Motor Company Driving Cycle
It describes the actions necessary to clear the P1000 code.
Just passing this along
Old May 3, 2009 | 01:01 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
for your gas smell, check out the TSB's for the Econoline. Ford had to issue a TSB to fix a gas smell in them. Same motor and everything, but for some reason no-one has applied it to the F-150, even though some guys are experienceing the same issue
From what I understand, they had a bad batch of injector o-rings. The #5 and #7 cylinder ones would leak and the evaporated fumes would enter the cab. The TSB basically said to replace all the injector o-rings
