Fellas,
First time driving at night andwhen i pulledover to get gas the batteries were dead, when i went to start it did the rrr rrr rrr and then stopped. Let it sit for awhile and nothing. Got a jump from a nice buddy here and it started right up, got home ok and all was well then thought well i should try to restart right? nope, it is dead again, now i know that when gas engines dont have a good alternator they will die when the battery runs out. will a diesel die or just keep going till you shut it off? What could be the problem? i am thinking wiring issues with lights, short, ground etc. Alternator is another possibility as the batteries are not kept at charge, i will go out with the multimeter tomorrow and check it out to see if she is getting the 14V or so when running. Oh and just read my signature again!!! LMFAO!!!
Something to look at is that that F150 cab came with a alternator with a built in regelator and the diesel has the external regulator so there has been some custom wiring done.
mine did that the day i bought it.i had the dealership fix it and evidently there is a regulator or something behind the dash that can go bad.whether there is truth behind it i dont know.but its something you may check into.ill look at my diagrams tomorrow.
Wel well my signature never lies, i jumped it this morning and it started and ran normally but i noticed that the volt meter was reading a bit higher and as i sat and checked it over it got higer and higher. I grabbed the multimeter and checked the batteries, both were at 12.56 and climbing, 5 mins later and it is at 14.4. I didnt do anything so i came to a couple conclusions,
1) it could be a ground/short in the wiring.
2) it sould be a ground/short in the wiring. hahaha.
I just need to find it and i think it is in the lighting system since that was the first time i rode at night. Also could be the heater fan or similar since we had the defroster on to give a bit of warmth.
George _ last night is was reading below normal so around 10v or less i guess.
star _ i am pretty sure the alternator came from the engine and not the truck, i think! haha
David _ I was hoping you would say that about the dying issue, it would make more sense that way. As for an alternator issue, it is working fine today and to my knowledge when the alternator goes.....it is gone.
So Fellas, i am going to do a lot of wire checking to find this damn thing. I need to get some people together for a wiring party and re-wire the whole thing!!!
Loose grounds would be my guess. Might also want to pull all the connectors to the alternator and external regulator (if equipped) to look for any signs of corrosion.
