Screws for decking
Old May 2, 2009 | 08:45 PM
Ford_Six's Avatar
Ford_Six
Screws for decking
I have to replace the decking on my car hauler, and I want to do it right this time. I used carriage bolts last time, but they kept working loose. I have seen some newer trailers with square drive or Torx drive screws holding the deck boards in place, where can I find these? I tried some self-drilling screws from Lowes, and they didn't grab the steel.
Old May 3, 2009 | 09:59 AM
80351's Avatar
80351
Hey Jared see you got a little bit of a problem. I love square drive screws but I don't know that they come in self tappers which would mean you would have to pre drill all the holes.
Lowes and Home Depot don't have them either I've tried and the only place I could tell you to get some would be some kind of fastner company.You could try a search on the internet for them.
I worked on trailers for many years and actually with what you are doing why don't you tack weld the decking down.
If you need somemore assistance you can PM me.
Old May 3, 2009 | 01:27 PM
Ford_Six's Avatar
Ford_Six
Wood doesn't weld very well-
I like having a replaceable nailable decking, so if need be I can nail blocks down, or if I damage it I can replace one board.
Old May 4, 2009 | 12:19 AM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Did you try lock washers?
And you might try looking at a trailer builder for deck screws. Most are Phillips or Robertson (square drive) in 1/4" fine thread self tapping. We have a bag of them at work, but I don't know where we got them or who we got them from.
Old May 4, 2009 | 07:51 AM
powerstroke72's Avatar
powerstroke72
Hey Jared. You might try this place. They've got stores a little bit of everywhere and carry great stuff at reasonable prices.
http://www.fastenal.com/web/products.ex?N=999600000
Old May 4, 2009 | 08:50 AM
AzBlueWolf's Avatar
AzBlueWolf
Trailer Floor Screws - Trailer Deck Screws
Old May 6, 2009 | 02:36 PM
n4aof's Avatar
n4aof
Take a look at eBay item 270318701532
Trailer Deck "Screw Kit" drill bit, T-30 bit, 150 bolts
Includes:
One T. 30 Screw installation Torx Bit,
150 Deck Screws special plated (for treated wood) self threading deck screws (5 rows of 30 screws) .
High Quality 7/32" Drill Bit; The Same Fast Cutting Bit Used By Trailer Builders.
Plated For Use on All Treated Wood Including New ACQ Treated Wood.
Screws are 1/4" by 2 1/2" so they should go through most decking lumber, and are flush when installed. These will cut threads into 1/4" steel.
This should be enough screws to do a average 18 foot flat bed trailer
Old May 11, 2009 | 10:54 AM
tecgod13's Avatar
tecgod13
Wood swells and shrinks with the weather, which is why the carriage bolts came loose. Lock washers may help, but probably won't do much. Use nyloc nuts or jam nuts, they won't loosen up no matter what happens.
Old May 13, 2009 | 02:43 AM
jake00's Avatar
jake00
Originally Posted by AzBlueWolf
we used this type of screw on our flatbed, works great
Old May 15, 2009 | 02:56 PM
rebocardo's Avatar
rebocardo
I use jam nuts on 1/4 bolts, washer under the bolt and nut. Tighten to about 15 pounds (using grade 8) until it makes a depression. Once the PT wood dries out, tighten, and then put a tack weld on the nut/bolt. I really do not care about the bolts sticking up a bit, they provide traction when the wood is wet, so I put them on nut side facing up and that makes the tack weld easy. If you care about how it looks or carry fragile stuff, then put the nut on the bottom of the trailer cross member.
When I replace a board I just grind the head off.
Old May 19, 2009 | 08:08 PM
wdfp's Avatar
wdfp
I was intending to just run some flat strap across the deck so the bolts go thru 2 pieces of metal, always seemed to work well in the past..
Old Mar 31, 2010 | 03:15 PM
Ford_Six's Avatar
Ford_Six
Now almost a year later, I am finally getting around to this-
Old Apr 1, 2010 | 09:09 PM
AzBlueWolf's Avatar
AzBlueWolf
about time...take pics!
Aaron-71
16
May 30, 2017 12:30 PM
dayde
Modular V10 (6.8l)
Jan 7, 2017 07:02 PM
Gaetznes
19
Aug 15, 2016 11:24 AM
Marc150
General Automotive Discussion
32
Jul 27, 2004 06:27 AM
Paso1
Jun 25, 2004 03:49 PM
