Frontend knock
Old May 2, 2009 | 01:25 PM
1950gmcelc's Avatar
1950gmcelc
Frontend knock
Hey guys i started to notice sometimes when i turn i am starting to hear a knocking sound coming from the frontend. Any ideas what this might be?
Old May 2, 2009 | 01:36 PM
rideracelivemx7's Avatar
rideracelivemx7
i heard a similar problem in my last truck, turned out to be the crapp ball joint i put in there, replaced it and didnt hear it again
Old May 2, 2009 | 05:42 PM
helifixer's Avatar
helifixer
if not ball joints it could be the axle pivot bushings if it is i.f.s. also check torque on the spring u bolts
Old May 2, 2009 | 06:49 PM
Aireeek's Avatar
Aireeek
Okay, so I know this sounds too easy, and I thought the same thing myself when a fellow member on this site offered me this solution but Ill be damned if it didnt work!! I had a knock every time I turned a certain direction or went up a driveway and it turned out that all I needed to do was tighten the nuts under the hood that held on my front fender. I did it and walla..no more knock. It could be any of the afore mentioned problems, but Im a optimist and look ofr the easy solutions first. Try to tighten down all these bolts and see what happens.
Reek
Old May 2, 2009 | 07:04 PM
BlueMule's Avatar
BlueMule
Take a look at this thread and see if it helps.
https://www.ford-trucks.com/forums/8...ml#post7259811
