Fuel Fitting Question
Old May 2, 2009 | 05:02 PM
Welk49's Avatar
Welk49
The fittings on the fuel pump housing that the return lines go to, are those 1/4 threads? Need to get a list together for pieces and parts for electric fuel system
Old May 2, 2009 | 06:28 PM
Gobstopper909's Avatar
Gobstopper909
do you mean on the fuel pressure regulator? they are 1/8 npt where they connect to the fpr. im unsure about the jic flare on the other end
Old May 2, 2009 | 06:53 PM
BlueMule's Avatar
BlueMule
Do you mean the 90* fittings on the pressure regulator where the fuel returns from the heads go? Those are -4 JIC on one end and 1/8 NPT on the other.
Old May 2, 2009 | 08:09 PM
Welk49's Avatar
Welk49
yes I was referring to the fittings at the regulator. Thanks
