trailer battery?
Old Jun 1, 2009 | 01:11 PM
Old Rusty Wrench's Avatar
Old Rusty Wrench
Most battery problems are due to low water level problems. Trailers with two batteries also have chargers when hooked to 120 volt AC. When your rig is at home hooked to 120 volts for long time it is charging the batteries. I know there 12 volt loads on the all the time (detectors, refer curcuits, tv antenna amps) that draw from the batteries. If the not hooked to power batteries will be drained down. Keep an eye on the water levels in all of the cells every three mounths. It will help the extend the life of deep cycle batteries.
tigman_tim
Jan 5, 2014 01:31 PM
skyoung
Nov 9, 2011 07:14 PM
gmcbride
Jun 30, 2007 09:28 AM
Jennifery
1983 - 2012 Ranger & B-Series
May 2, 2007 12:14 AM
seawulff
Aug 29, 2005 04:11 PM
