torque converter
Old May 2, 2009 | 08:43 AM
swordman's Avatar
swordman
torque converter
hi i'm new here what i would like to know is i rebuilt my c6 trans (1st one) i'm getting ready to put it back in, when i go to put it in should i prefill the new (remanufactured)converter with fluid before installing? Thanks
Old May 2, 2009 | 10:05 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Yes
-Enjoy
fh : )_~
Old May 2, 2009 | 10:30 PM
stuart1's Avatar
stuart1
It's not necessary to fill the convertor before installation.
The pump will fill it in no time.
Old May 2, 2009 | 10:40 PM
Festus Hagen
Methanoholic
Really, it's ok to fire up with a dry torque converter??
That is something against what I have always been told or seen, I have always been told to fill it!
In fact recently on one of the powerblock shows they said to fill it first.
I dunno know, I am no Automatic Guru, I hate them! (Just a personal pref)
-Enjoy
fh : )_~
Old May 2, 2009 | 10:48 PM
stuart1's Avatar
stuart1
I have installed thousands of transmissions over the years and never prefilled one convertor.
Think about it.
The only way to prefill a convertor on the bench is lying flat.
Once you turn it for installation the red stuff will pour all over the place.
If you are so inclined pour a quart into it.
Old May 2, 2009 | 11:25 PM
jk080's Avatar
jk080
Transmission Rebuilder
We never fill them first, in any make or model, Ford, Honda, MB,BMW,ect.
When you rebuild a converter, you would use a lubricant on the bearings and all converters should be balanced full of fluid anyways, so there the clutch (if equipped) would get a presoak.
Bottom line if it makes you feel better to pour a quart in, do it you wont hurt it, but it might get messy.
Old May 3, 2009 | 12:07 AM
Festus Hagen
Methanoholic
I wasn't arguing ... I did say "I said I dunno know"!
I know nadda about Automatics and don't care to.
It's just what I've always understood, and I did just see one of them shows fill theirs with Royal Purple, I think they did only put a qt in it.
Pre lubed, understood!...
Cool, Learn something new everyday!
As far as adding a qt... NOT ME! because I won't be stuffing no Automatics anywhere except in the dumpster!
Just a personal preference, they are fine for those that like them, I hold nothing against those that like them, I just don't like them!
-Enjoy
fh : )_~
Old May 3, 2009 | 12:13 AM
stuart1's Avatar
stuart1
No argument noted.
Merely discussion.
Old May 3, 2009 | 12:21 AM
swordman's Avatar
swordman
thanks for all of your responses. I like the automatics sense i've gottin older and lazier LOL thanks again
Old May 3, 2009 | 12:37 AM
Festus Hagen
Methanoholic
I wish I was lazy...
My body can't keep up with my minds desires!
-Enjoy
fh : )_~
Old May 3, 2009 | 08:15 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Ford builds A LOT of transmissions every day. Each one of them has a dry torque converter installed. The converter is filled when the trans is filled and run.
