Throttle Body Spacer
Old May 1, 2009 | 10:33 PM
dpellicone's Avatar
dpellicone
My '85 F-150 is an 5.0 302 with EFI. They only make throttle body spacers for carbs for that year since EFI was only in option for the '85 and did not become standard until '86. Would a throttle body spacer for an '86 fit my '85?
Old May 2, 2009 | 12:53 AM
86bigred's Avatar
86bigred
i think they are only usefull on throttle body injectors.i can't see any benefit on the multi port injection.but i've been wrong before.
Old May 2, 2009 | 12:56 AM
86F150302's Avatar
86F150302
Waste of money.. Spend that money on exhaust or something else.
Old May 2, 2009 | 01:19 AM
LCAM-01XA's Avatar
LCAM-01XA
Depends on what kind of spacer it is - you want one with a smooth bore, it's used to increase the effective length of the runners, making for some increased low-end torque. A spiral-bore spacer like those air-raid ones will only mess up your airflow - they are designed to create turbulence to aid in fuel atomization, the problem is they create the turbulence right at the TB, and fuel injection happens way further down near the cylinder heads, so while the whole idea is very feasible for TBI systems a MPFI will not benefit anything from it. The spacer that does work pretty good is the intake spacer, it's a phenolic spacer that gets sandwiched between the upper and lower plenums, it also increases runner length, but it also limits amount of heat transferred to the upper intake, thus making for somewhat cooler air charge entering the cylinders.
Old May 2, 2009 | 07:04 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Throttle body spacers are useless, even more so on a truck 5.0/5.8, the TB is heated. You would get better results out of a plenum spacer, it lifts the plenum off of the lower intake.
86 f150 302 efi
Feb 8, 2011 04:37 AM
ADAMS96
Mar 3, 2010 10:16 PM
daboot
Nov 3, 2009 05:51 PM
JakeTheSnake
Jul 18, 2006 03:57 AM
paulg
May 25, 2001 05:19 PM
