64 Interior Knob Layout Question(s)
Old 03-08-2014, 07:09 AM
1964FORDTUF's Avatar
1964FORDTUF
1964FORDTUF is offline
64 Interior **** Layout Question(s)
Howdy all -
On my 64, not a custom cab, the layout of the control ***** seem to have been changed around a bit in the past 50 years..go figure! On the right side of the steering wheel on the dash, there are 3 original holes in the dash for ***** / controls. An after market choke cable was installed in farthest left hole, then a throttle ****, then the heater motor / pull for defrost ****. I don't think the throttle **** is original either and I don't really need it. Does anyone know the "proper"or correct layout of the *****? I think the original choke needs furthest left, then the **** to control heat on / off, then the heater fan control / pull for defrost ****?? Sound right?? Any pics would be appreciated...!!!
Old 03-08-2014, 09:19 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Took a picture but can't figure out how to post either with the app or the full site. (Ok, 20 bucks and two hours later, here is a blurry pic, lol) My stock 64 has a chrome delete plate for the leftest hole, next is choke, then the fan control.
Old 03-08-2014, 03:16 PM
1964FORDTUF
Originally Posted by Tedster9
Took a picture but can't figure out how to post either with the app or the full site. (Ok, 20 bucks and two hours later, here is a blurry pic, lol) My stock 64 has a chrome delete plate for the leftest hole, next is choke, then the heater control.
What are the two lower ***** I see below the dash if you don't mind my asking?
Thanks
Old 03-08-2014, 03:44 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Sure.. This truck has the Fresh Air Heater, an extra cost option (pretty fancy!) and those are two of the three controls for the heater., HEAT and TEMP.
The FAN control has OFF, LO, and HI, pulling it out directs air on the windshield for defrosting. The HEAT control brings outside fresh air into the cab. TEMP regulates how hot the cab gets. Works good.
Sent with smoke signals using campfire
Old 03-09-2014, 03:27 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Right of column: 9775 throttle cable or 374052-S blankout plug - 9700 choke cable - 18578 heater blower switch/cable or 18607 blankout plug.
1961/64: The recirculating and deluxe fresh air heaters were optional, but all came with the choke cable. Throttle cables may be installed in F500/1100's, but I've seen a few in F100/350's.
Old 03-09-2014, 04:59 AM
1964FORDTUF
Thanks as always Bill...
okie trucker
12-03-2018 06:06 PM
schmiddw
08-19-2018 07:23 PM
skidoorulz
21
01-31-2015 08:17 PM
mtford
10-06-2007 11:12 AM
mr4speedford
06-20-2003 03:02 PM
Quick Reply: 64 Interior Knob Layout Question(s)
