2004 f-350 need help!
Old May 1, 2009 | 07:18 AM
52panhead's Avatar
52panhead
Hi all, had to sign up with a different handle since it's been so long since I've posted. Anywho I have an '04 f-350 6.0. I blew a head gasket right after pulling a cargo trailer back from FL. Got that fixed (3 weeks) and when I picked it up it didn't have ANY turbo boost. After ANOTHER 3 weeks the mechanic at the Ford garage has thrown enough parts at it to sink a battleship, including the latest ford approval to put another turbo on it. Does anyone have any suggestions as to what I may suggest to the mechanic to try or check out? I'm about ready to lose it on the stealership. I obviously have been without a truck for about 45 out of 60 days. HELP!!!
52pan
Old May 1, 2009 | 07:19 AM
52panhead's Avatar
52panhead
Oops, I forgot to add that even AFTER the new turbo it is not building any boost.
52pan
Old May 1, 2009 | 07:48 AM
bismic's Avatar
bismic
Can you give us a list of what has been replaced already?
The symptom of not building boost can be a number of things - including a bad PCM.
Old May 1, 2009 | 10:07 AM
BobsF350's Avatar
BobsF350
if you were coming up I75 north of tenn.ill bet Jellico took it out.
Did the check the boost hoses and tubes? ask him if he can pressurize the whole system to see if a leak is not letting it build boost
Old May 1, 2009 | 12:42 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE 52panhead......
Old May 1, 2009 | 02:42 PM
52panhead's Avatar
52panhead
It's hard to figure out what they've replaced on this visit (extended) to the dealership. I'll have to dig out the previous reciepts to let someone figure out what's happened.
Everything was fine until about 40,000 or 41,000 miles then I had a left ball joint go out, then the water in the fuel drain plug (brass) stripped out necessatating a new face plate and some type of new two into one harness (for the fuel pump assummingly). Next visit was about injector or inj. harness problems. That was another 3 week fix. Now the problem after the head gasket was replaced.
If I PM someone with the VIN # can/would an explanation be possible as I don't read Ford mechanic latin code.
Sincerely, 52pan
Old May 1, 2009 | 03:18 PM
brickie's Avatar
brickie
Post the VIN in the Oasis thread in the superduty forum and someone will get the history.
Old May 3, 2009 | 10:16 PM
52panhead's Avatar
52panhead
Brickie- will do.
52pan
