Engine Ground
Old May 1, 2009 | 06:03 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Engine Ground
Gunna fit my trans temp gauge this weekend. The earth is spose to go to the engine ground. Where to find such a bugga ??
Old May 1, 2009 | 06:18 AM
Izzy351's Avatar
Izzy351
Not sure on yours, actually. Look around -- you'll see a strap going from the block to the fender or fire wall someplace. BUT, it doesn't really matter. All you have to do is screw it into the test port on the trans. Don't use any teflon tape or anything. The outer part of the sensor with the threads is the actual ground for it.
Old May 1, 2009 | 06:33 AM
ChunderDownUnder
Was just following the instructions from the gauge. It has two pins on the back. One for the sensor and one marked engine ground.
Old May 1, 2009 | 06:38 AM
megawatt00's Avatar
megawatt00
The one marked engine ground can go to any ground source that you have closeby.
Old May 1, 2009 | 06:48 AM
Izzy351's Avatar
Izzy351
Oh -- yours is significantly different than mine... Carry on....
Old May 2, 2009 | 03:57 AM
ChunderDownUnder
Found it
It runs from the block up to the firewall right in front of the drivers side.
(thats the passenger side for you guys.)
Old May 2, 2009 | 04:35 AM
just another truck's Avatar
just another truck
Originally Posted by ChunderDownUnder
Found it
So do your mail trucks have their driver seats on the other side??
Are you all set then, Guages all work?
Old May 2, 2009 | 05:08 AM
ChunderDownUnder
If ya talkn bout the vans with the sliding doors, we dont have em.
Every one over here drives from the right side.
I painted the pillar mount tonight. will give it another hit tomorrow mornin.
Then I will put in the Pyro sensor and trans sensor. All the wires are hooked up ready to go, just gotta wait for the paint to dry.
BTW, how the hell do you get the pillar mount back in ?
Had a dumby run when I fitted it to the factory pillar. those pods hit the dash when I treid to get the bottom in.
Old May 2, 2009 | 07:57 AM
just another truck
I remove the door weather seal now, pulling it off just in that area.. Angle in the bottom first, watching the clips, trying not to force anything, while forcing it.. I have gotten rather good at it, but still dont enjoy it.
But feed the bottom first, you need to be angled toward the seat , if you go to close to the window your clips will be on the wrong side of the pillar support.. Like I said though, pulling the weather stripping ( towards the door ) allows me to watch the clips. I always use a screw driver to help guided the bottom, then the second clip into place.
