Afternoon Marty. The last alternator I replaced on the truck would cause all of the lights to flicker from normal top really bright. When I had it tested it would test fine. I replaced it anyway and problem solved.
I am baaaaaaaaaacccccccccccckkkkkkkkkkkkkkkkkkk !!!!!!!!!!!!!!!!!!!!
Doug, that is not good with only getting 2 volts.
Battery light came on after I went to an MVC. Had the day off today so I replaced it after answering a call this morning. Figured I better change it before it leaves me stranded.
That is always the better way to do it. So how have you been??
