horrible screeching noise
Old Sep 12, 2002 | 08:31 PM
RBrendel's Avatar
RBrendel
okay i have and automatic 351 i think with the e40d. if i give it too much throttle and right before it hits second gear there is the horrible screeching sound from the rear end, as i hit higher gears the noise goes away. it only does this if i give it a little more throttle than usual any ideas?
Old Sep 14, 2002 | 12:10 PM
RBrendel's Avatar
RBrendel
just for the record even though nobody responded to my problem i got it checked out and it turns out that all my u joints are bad and my carrier barring is fixing to go out. the barring is what was making the screeching noise.
Old Oct 3, 2002 | 03:55 AM
thoseapples's Avatar
thoseapples
&nbsp&nbsp&nbsp That is an integral carrier? How much is the repair estimate, and what procedure are they using to extract the old bearing?
Old Oct 5, 2002 | 08:01 PM
924x2150's Avatar
924x2150
if I saw this in time I would have said driveshaft. Those bearings are out in the open and will make alot of racket, as opposed to bearings down in a housing or between housings
Old Oct 5, 2002 | 08:24 PM
Pickup Man's Avatar
Pickup Man
Sayer Lane
Jan 10, 2010 12:33 PM
weekendwarriorfsw32
Feb 19, 2009 10:14 AM
JD717
General Automotive Discussion
Aug 15, 2005 11:38 PM
Thumper4995
Jun 14, 2004 02:35 PM
cwh82
Oct 30, 2003 04:04 AM
