Question About Starting
Old Apr 30, 2009 | 08:50 PM
kwissman's Avatar
kwissman
I have had my 05 for 2 weeks. It has 44k miles. This is my first diesel, so my background is with gassers.
I am not sure if I have a hard starting condition or not. I have to crank if for about 3-5 seconds before it starts. It seems like it is taking a while to build HP to fire the injectors. It is not cranking over slow or anything like that. I also wait until the glow plug light goes off and the temp has been 70+ since I got it. It has been doing this since I got it and do not know if this is normal or not. I have no smoke and it runs great after it starts.
I changed the oil last weekend with 5-40 Valvoline Extreme Blue synthetic and also changed the fuel filters with no change to the way it starts.
The OASIS did not show the STC fitting being replaced yet, so I am wondering if I have a valid concern or not.
Thanks
Old Apr 30, 2009 | 09:07 PM
bismic's Avatar
bismic
It may not be an issue. I do not think 3-5 seconds is bad. Mine starts a little quicker (in 2-3 seconds), but I don't think Ford feels that 3-5 seconds is unacceptable. If I were you, I would load check the batteries just to eliminate that possibility.
I guess it could be a HPO issue developing. However, many times this will begin to happen when hot and not as bad when cold. Does it happen with a hot and a cold engine?
Another possibility may be a restricted intake or exhaust.
Old Apr 30, 2009 | 09:15 PM
kwissman's Avatar
kwissman
It seems to be pretty consistent. It does not take any longer when hot. I will check the batteries just in case. They are 4 years old.
I guess I should quit reading and worrying and just enjoy the truck.
Old Apr 30, 2009 | 09:23 PM
bismic's Avatar
bismic
I understand the "concern" on the STC fitting. If I understand the dates correctly (for the Ford "fixes"), I missed having the STC bracket installed on my 2006 by a few months. I approached my dealership about doing the STC replacement when they are in a slow time at the shop. They said they would do it at a discount, but it would still be fairly expensive. I just do not want to have to have it done at a shop that I do not know anything about (ie on a long trip). Decisions - decisions!
Bottom line .... your own advice is wise - quit worrying and enjoy!
(Don't stop reading though !!!!)
Old Apr 30, 2009 | 09:25 PM
miner999r's Avatar
miner999r
Mine definitely takes more cranks on the starter than my old 7.3. As long as it starts I wouldn't worry about it, from your description.
Reading other posts, I would follow advice to make sure your batteries and charging system are A OK.
