03 6.0 problem
Old Apr 30, 2009 | 07:22 PM
eddiedebb's Avatar
eddiedebb
03 6.0 problem
Hope someone can be of some help with my new problem. Last week my 2003 F250 6.0 was blowing black smoke, no power and hard to start. Sooo I took it to the ford dealership. The dealership I choose has the only master mech in the area and is aslo a diesel mech. The following is his report:
inspect and diag steps 1-15. Retrive DTC for MAF, Turbo, and EGR system. Replaced EGR, Turbo, MAF and retested. Started truck and ran. Reset KAM and truck will not start. Found PCM defective and replaced. PCM would not program. Found fuse blown and pinpoint test found 2 wires broke at PCM and 2 on MAF.
Well...after all of that...some of which was unnessarry and expensive, i am tapped out money wise. The truck ran great on the 40 mi trip home and i parked it for the night. the next morning it cranked up great and i headed into town, 3 miles, to the hardware store. Came out of the hardware store after about 30mins and crancked the truck. It was idling very rough and when i started down the road it did not have any power. I got it home ok and have run it a couple times to the same fate...rough idle, no power.
I called the mech and he suggested I trade it off because if I bring it back in he feels that the injectors and or the ficm is bad and could end up costing 5-10,000 to to the repairs. He also said he would recommend new wiring harnises
I pulled the codes and the only one is 1780( transmisson overdrive selector out of range).
Not sure if I trust this guy anymore and I dont have that kind of money to spend. I was just wondering if the PCM or the FICM may have lost its programimg or if a wire shorted out some place. Any suggestions or help would be greatly appreciated.
Old Apr 30, 2009 | 08:44 PM
thado's Avatar
thado
Trailering
How far is “too far” to travel when it comes to getting your Powerstroke repaired properly ?
Go to powerstrokehelp.com
Spend some time listen to Bill´s lectures in his video series on Power Stroke.
You are in Texas , he´s in Georgia -- not too far ?
Replaced EGR, Turbo, MAF, PCM, and now suggesting to replace the truck !! Come´n.!!
By the way, how many k. has the truck ? Any mods?
Hope you find a good mech.
bs.
ljutic ss's Avatar
ljutic ss
Sounds like you have an electrical problem for sure, but I would demand they fix the truck without throwing any more parts at it. They pulled that crap on me back in 1990, I had a 1988 Ranger and the motor would cut out for a split second a few times a day. The truck was in the shop 3 different times for days at a time threw every module, sensor, controller the truck had into it and finally it turned out to be a chaffed wire. Ford warranty paid for it all about $1,500 back then.
Old Apr 30, 2009 | 08:58 PM
eddiedebb's Avatar
eddiedebb
The truck has 133k. The turbo did have a cracked housing and was stuck in the open possition. Chasing a wire problem is like trying to catch a ghost.
Georgia is not that far but i dont think my truck would make it that far.
Old Apr 30, 2009 | 09:46 PM
thado's Avatar
thado
Trailering
So now your techn. feels that the injectors and or the ficm is bad. He might also feel he HPOP is bad or IPR (induction pressure regulator) or the ICP (indution control pressure sensor) or quite many other components are bad. Hopefully he picks the correct items sooner than later. Sry my feeling is bad, but your should read all you can in the tech folder in the " 2003 - 2007 6.0L Power Stroke Diesel" forum. It might give you a clue.
Old Apr 30, 2009 | 10:27 PM
eddiedebb's Avatar
eddiedebb
I am begining to think that the PCM and FICM needs to be re flashed. It is strange that the PCM is not showing any trouble codes. I would think with the truck running so bad that some kid of code would show up.
Old Apr 30, 2009 | 11:58 PM
supertruck60's Avatar
supertruck60
Hot Shot's Secret might help
Hi,
This sounds like a very frustrating situation. I cannot interpret the codes that are now coming up but wanted to address your comments about injector replacement. We always recommend our product before replacement.
If the injectors are suspected as the source of the problem, it can be due to stiction. Stiction is a very common issue in the 6.0 due to the design of the injectors.
We developed our oil additive for International to attack this problem at its core. It was tested and proven safe and effective. There is a 100% guarantee so there is no risk.
A lot of times we hear about poor starting issues, turbo lag, noisy or malfunctioning and other such performance problems...one treatment with Hot Shot's Secret can solve these. 86% of the time Hot Shot's Secret was shown to resolve the issue and improve it for the remaining 14%...not too shabby!!
Please see our website at Lubrication Specialties | Diesel Motor Oil | Primrose Engine Oil | Fuel Additives | Oil Additives | Engine Restore| for more information.
I am posting the article about stiction and how the injectors are affected and how Hot Shot's Secret fixes this issue.
I hope you get this resolved quickly and easily. Feel free to contact Chris anytime by phone or email if you have questions.
Best,
Dan
How To Solve Power Stroke Diesel Truck Injector Problems Inexpensively
Hot Shot's Secret has finally solved the common and costly fuel injector problems diesel truck owners have lamented for years.
To increase the efficiency in modern diesel engines, manufacturers have increased the pressure at the tip of the injector. This increase provides for a better, more efficient burn with added power. Older injectors would put out 1,200 psi at the injector tip but the new diesel engines put out 26,200 psi at the tip. To achieve this increase in pressure the manufacturers had to tighten the tolerance inside the injector. This increased the friction and temperature. The higher temperatures have a burning effect on the engine oil. A layer of oxidized oil and additives form, slowing down the injector and eventually stopping it altogether.
"Injectors in the diesel truck engines have a high failure rate," says Chris Gabrelcik, lubrication engineer, CEO of Lubrication Specialties, Inc. and the creator of Hot Shot's Secret. "Injector issues cause slow start-up, rough idling, hesitation, and lack of power because the injectors aren't firing properly." Until now, owners had to replace their existing injectors, often spending up to $2,500.00, with no guarantee that the problem would not occur in the future.
An amazing 86% of the time, Hot Shot's Secret solves the problem completely, and for the other 14% it has made a significant improvement. "We've got a money back guarantee and if it doesn't work, we'll credit you," says Gabrelcik, who acknowledges the fact that in some instances the product might not work because of other mechanical failures.
Originally created for International Truck and Engine, Hot Shot's Secret is an additive made from a combination of detergents and dispersants. Once added to the vehicle’s crankcase, Hot Shot's Secret removes build-up, the coking and varnishing left behind from overheating of the engine’s oil. "It's the only thing you can put in your engine that will clean it out and actually solve the problem," says Gabrelcik, who spent two years sending dozens of different formulas around the country to be tested in various terrain and weather conditions. The final product was rolled out in November 2005.
In addition to the improved injector performance, Hot Shot’s Secret’s formula will also clean the deposits in the engine and turbo and will fortify existing oil, thus helping it to work more effectively. It only takes 64 ounces of chemical to clean 100,000 miles of build-up. 32 ounces every 3-4 oil changes will prevent the problem from recurring. Lubrication Specialties has customers on record with 500,000 miles on their trucks and are still using the original set of injectors.
Gabrelcik, who has been in the industry for over 14 years, founded Lubrication Specialties in 1997. He has extensive experience working with vibration analysis, oil reclamation, and lubrication consulting with countless national and local companies. For more information, please call 800-341-6516 or visit www.lubricationspecialties.com .
Old May 1, 2009 | 04:09 PM
eddiedebb's Avatar
eddiedebb
Been working on this problem all day and I did the vgt relearn/KAM thing. I was suprised with the results. Now the truck idles rought and has sluggish take off but runs great once you get her moving as long as you keep the RPMs above 1500. Still dont have any codes and that kinda bothers me.
Maybe I will try some of that Hot Shot stuff.
Old May 1, 2009 | 04:14 PM
brickie's Avatar
brickie
eddie has the ICP pig tail been replaced do you know?
natem8301's Avatar
natem8301
Sorry man...I can't offer any advice but it sounds like that mechanic just throws parts in instead of finding a root cause.
Old May 1, 2009 | 04:27 PM
eddiedebb's Avatar
eddiedebb
Icp
Not sure if that pigtail as been replaced. Is that an area of concern and how would i do it?
Old May 1, 2009 | 04:35 PM
brickie's Avatar
brickie
That pig tail can cause all sorts or running issues by screwing with the signals sent to the FICM. The easiest way to tell is grab a flash light and have a look. The icp is under your turbo and covered with silver cloth heat wrap. The wrap can easily be pulled back to expose the wires, if you do not have 3 purple wires going in it needs to be replaced as there is a known issue with the crimping at the plug. You can see them from on top of the motor with a flash light once you get your arm out of there. Hope this is your issue, please post back if it is.
Old May 1, 2009 | 05:20 PM
eddiedebb's Avatar
eddiedebb
I can see what looks to be foil tape and white cloth on the end of the tape. Is that it? Does it just unplug ...Motor is to hot right now to stick my hand in there.
Old May 1, 2009 | 05:26 PM
brickie's Avatar
brickie
You won't need to unplug it to see the wires just pull the cloth wrap back up the harness. The foil tape is wrapped around heat cloth, the connector you want has three wires.
Old May 1, 2009 | 05:49 PM
eddiedebb's Avatar
eddiedebb
According to the print out I have, Ford replaced the icp on 12-21-05 on recall 03B05.
Do I still need to check the wires?
