High idle mod
Old Apr 30, 2009 | 10:41 AM
joe blow's Avatar
joe blow
High idle mod
Hello,
I did the high idle mod on my 2004 PSD, works awesome.
Does anyone know if this is possible on a 2003 Excursion with the 6.0L?
I can almost assume the wiring harness for both vehicles is probably identical.
Thanks
Old Apr 30, 2009 | 10:57 AM
cartmanea's Avatar
cartmanea
Yes it should be the same.
Old Apr 30, 2009 | 05:03 PM
william_04_x's Avatar
william_04_x
no, it's not so easy...you have to run your own wire to the PCM..I've done it and it works great...
Old Apr 30, 2009 | 10:44 PM
joe blow's Avatar
joe blow
william_04_x,
Do you have any detailed information on how to do this?
Thanks
Old Apr 30, 2009 | 10:49 PM
riggz's Avatar
riggz
The wire for the high idle is for an aftermarket PTO which isn't usually installed in Ex's so the wire isn't there. But like william said it is possible by running your own wire.
Old May 1, 2009 | 08:03 AM
joe blow's Avatar
joe blow
The vehicle in question belongs to a friend of mine. I haven't looked at it to be honest with you.
When you guys say "run your own wire to the PCM", does this involve opening the PCM to route the wire or is it a matter of running a wire to the PCM and splicing into another wire?
Thank you
Old May 1, 2009 | 09:28 AM
riggz's Avatar
riggz
You would have to add a wire to the PCM connector. I think william has done a write up somewhere.
