Transmission problem
Old Apr 30, 2009 | 08:32 AM
jcferg's Avatar
jcferg
1998 Ford Explorer with automatic transmission. While driving at a steady speed the transmission will down shift, up shift and shift erratic, it seems to do this at all speeds. Very noticeable driving at 45-50 mph, the transmission will shift back and forth between 3rd and 4th gears while driving at a steady speed. The transmission is not slipping. After a couple of days of driving with this problem the check engine light went on, code P0705 (Transmission Range Sensor Circuit malfunction (PRNDL Input)). I replaced the Transmission Range Sensor/Neutral safety switch, still have the same problems. Anyone have any ideas. Thanks
Old Apr 30, 2009 | 07:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It could be the wiring to the TRS. The code doesn't necessarily mean the sensor is bad.
Old May 1, 2009 | 02:24 PM
jk080's Avatar
jk080
Transmission Rebuilder
Check the Light Blue/Yellow wire at the range sensor it should have 5 volts. If there is no voltage there check the square 16-terminal connector at the back of the engine, above the transmission bell housing, check for the 5 volts on both sides of that connector on the Light Blue/Yellow wire. I have had a bad connection there once before that caused the same problem you are having.
hdel
Jan 6, 2015 09:39 AM
Ragzz
Apr 21, 2014 07:03 AM
bullet head
1997 - 2003 F150
Jan 16, 2014 07:43 PM
TPM
Apr 12, 2007 08:21 PM
freddo32
1997 - 2003 F150
Aug 24, 2001 09:46 PM
