fuel tank size?
Old Apr 29, 2009 | 10:37 PM
rockcrawler_101's Avatar
rockcrawler_101
fuel tank size?
What size fuel tank would my 01 f250 extended cabe long bed.
Old Apr 29, 2009 | 11:20 PM
wpkeeper's Avatar
wpkeeper
I've got a 50gal in my 01 f250!!!!!!!!!!!!! sorry, don't remember what the stock one was...
Old Apr 29, 2009 | 11:48 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Stock should be 40 I believe, unless you do the tank mods then I hear about 44...
Old Apr 30, 2009 | 01:14 AM
liftedgrocerygetter's Avatar
liftedgrocerygetter
Long beds have a 38 gal in them. I have got almost 39 in mine once but I had run it wayyyyyyy down....
Old Apr 30, 2009 | 01:32 AM
Visseroth's Avatar
Visseroth
Mine is rated at 38g and I have put 38g in it before when the needle was pegged empty
Old Apr 30, 2009 | 08:36 AM
HKusp's Avatar
HKusp
Really? My 29 gallon rated tank, if I take my time, I can get 31 gallons in it almost every time I run it down. I would think you 38 gallon guys/gals could at LEAST get 40 in yours, but I guess the different configuration means no go.
Old Apr 30, 2009 | 09:51 AM
brian42's Avatar
brian42
Veteran: Navy
That's because the filler and vent tubes stick several inches down into the tank (4-6" of PVC IIRC). This will shut off the pump prior to being full giving you a capacity rating of 28 gallons. If you keep clicking the pump to "top it off" you can get a couple of more gallons in there. If you go in and clip those tubes (known as the "hutch" mod) you can get several more gallons in the tank. I routinely put 30 gallons in (and the low fuel light isn't even on) on fill-up on my "28" gallon tank on my short bed and go nearly 500 miles between fill-ups.
Old Apr 30, 2009 | 11:07 AM
HKusp's Avatar
HKusp
Oh yeah Brian, I am fully aware of the Hutch and Harpoon issues. It's definitely on my "to-do" list. I just thought the big tank trucks had the same issue us 29 gallon guys did.
Old Apr 30, 2009 | 11:43 AM
brian42's Avatar
brian42
Veteran: Navy
My bad. It's the 'harpoon' mod, not the 'hutch' mod. I did them at the same time so I keep getting them backwards. The 'harpoon' clips the tubes in the tank and the 'hutch' mod fixes a lot of the air introduction to the suction of the fuel pump. I don't recommend dropping the tank just for the 'harpoon', but if you're already in there, it's worth the 2 minutes to clip those PVC pipes.
