clutch problem ?
Old Oct 10, 2002 | 02:47 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
clutch problem ?
i have a 90' f150 w/ 300 I6 4x4 5spd, just took it on a cross country trip. the clutch acted funny on the whole trip. when on the highway at normal speeds for an extended amount of time the clutch would act up. whenever i went to shift the clutch pedal would sink almost all the way to the floor before i would feel it do anything. and once it didnt do anything, it just dropped to floor and stayed there. whenever i started moving through the gears the problem would dissappear. street driving is fine, only on extended highway trips will the clutch act up. if anyone could shed some light on this mystery i would greatly appreciate it.
J.R.
90' f150 xlt lariat
300 I6 4x4 5spd
3" body lift and 33 x 12.5" tires
Old Oct 10, 2002 | 05:17 PM
mrshorty's Avatar
mrshorty
clutch problem ?
Kind of a guess, but could it be the hydraulic/brake fluid? Low on fluid? fluid has water in it and boils when it gets hot enough causing a bubble in the line that allows the pedal to fall to the floor?
Old Oct 10, 2002 | 09:37 PM
Mike W's Avatar
Mike W
clutch problem ?
This is a strange one. Has to be something to do with the hydralic linkage. Let us know what you find.
Old Oct 11, 2002 | 08:15 AM
jrs_big_ford_f150
clutch problem ?
i'll keep poking around in the tranny. the fluid is fine, a little off color from age but it is still at the top of the filling hole. i plan on changing out all the drivetrain fluids soon (2 diffs, tranny, and transfer case) maybe that might fix it if there is water in with the fluid. be cheap and easy to do before i look into the linkage
J.R.
Old Oct 11, 2002 | 09:29 AM
FortyFords's Avatar
FortyFords
clutch problem ?
its either the slave cylinder leaking by or the clucth master cylinder
leaking by . look for evidence of leakage around the bottom of the bell housing or the clutch pedal pushrod that goes through the firewall.
You aren't going to like this but its a sealed unit requiring the entire
systen being replaced !
Rich
Old Oct 11, 2002 | 10:59 AM
lanero's Avatar
lanero
clutch problem ?
My truck did the exact same thing. Just before the trans ate itself. What is happening is that something is overheating the slave cylindar and boiling the fluid. The reason mine did it was because it spun the input shaft bearing, and then proceeded to eat the input shaft gear. Make sure your trans is full of (good) fluid and then try to determine what is causing all of the heat.
Roger Lane
Old Oct 11, 2002 | 12:11 PM
padd77's Avatar
padd77
clutch problem ?
You need to check the fluid that is in a little cup that is located beside the master cylinder and not the fluid in the transmission its self. I think that this was given eariler in another post, but your reply back to it sounded more like you checked the fluid in the transmission and not under the hood. It really sounds like you are low on fluid or the line has air in it. Hope this helps.
Old Oct 11, 2002 | 04:50 PM
HD61cuin's Avatar
HD61cuin
clutch problem ?
mattri
Jun 15, 2014 12:32 PM
mercury89
22
Aug 15, 2008 03:49 PM
blackbikebmx
May 29, 2007 06:03 AM
lost_in_space
Feb 17, 2007 12:52 PM
PA F150 4X4
Modular V10 (6.8l)
Aug 6, 2003 10:07 AM
