batteries dead
Old Apr 30, 2009 | 10:01 AM
vettdvr's Avatar
vettdvr
Originally Posted by mattpowerstroker
thats what i figured but wouldnt i have had the batterie light or anything let me know that it was going.. what kind of brand should i go for with a new alternater.
If you have a failed diode in the alternator (1 of 3) it will put out 2/3 the normal. Given some inefficient frequent stop and starting it probably won't put enough power to quickly charge the batteries and end up low enough to not start.
The 2 of 3 diodes will sometimes not give you the light. If you have a scope you could see the output with a missing pulse.
Correct change the alternator. Brand. I use new OEM parts.
Old Apr 30, 2009 | 05:04 PM
Visseroth's Avatar
Visseroth
Well I know what alternator I'm getting when it's time for replacement.
Anyhow, back to the subject at hand.
Old Apr 30, 2009 | 05:28 PM
vettdvr's Avatar
vettdvr
If you have run your batteries down I highly recommend you leave all electrical not needed items off until your batteries have about 20 minutes to recharge. There is a risk on some alternators trying to full charge the run down batteries and full driver electrical load that alternators can overheat and fail. So just keep the a/c, radio etc off for about 20 minutes after start up to help out the alternator a bit.
Old May 1, 2009 | 02:25 AM
Visseroth's Avatar
Visseroth
Could just plug in a battery charger and top them off with a nice easy going trickle charge over night
Cell's
May 3, 2011 12:45 AM
ChurchBuilder
Dec 28, 2006 05:46 PM
roscoe
Electrical Systems/Wiring
Feb 2, 2006 09:19 PM
ddkrueger
Jun 20, 2005 10:09 AM
howefiretr
Jan 28, 2002 07:09 PM
