U joint problems?
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds
.Thats it for now, saving for a stang. Check out my Gallery for a look-see.
Justin - One Happy FTE Member
also while haveing those out
check the barings for loosness on the out shaft of thr trans and the in on the t case
ALSO check and see if your t case is loose ( i threw some safts because of this before)
tighten up all bolts and brace
i have pulled both yokes of and clean and inspected them and checked the bearings and put new seals in about 4 months ago and since then I have gone threw two U joints one lasted two days and I broke it and the ear of the drive shaft slip yoke will I was truck pulling so it has a knew slip yoke on it then I put a rockwell u joint in it and pulled three more times with know breaks or know problems until two days ago i heard a noise and checked the u joint and it is bad again it has about a 1000 miles on it and some I was only getting 300-500 miles Do you think truck pulling could be part of the problem
