U joint problems?
Old Oct 10, 2002 | 02:39 AM
FORDNUTTZ's Avatar
FORDNUTTZ
U joint problems?
Old Oct 11, 2002 | 08:15 PM
Fordman7780's Avatar
Fordman7780
U joint problems?
My 1977 ford highboy middle shaft has been going threw u joints every 1000 miles it is only the front u joint that does it i have had the shaft balanced and it was not out of balance my transfer case mounts are tight and my tranny mounts are good my truck has a 400 4speed and a 205 case Have any suggesting
Old Oct 11, 2002 | 09:05 PM
MustangGT221's Avatar
MustangGT221
U joint problems?
Is there an excessive angle being put on it from a lift?
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Thats it for now, saving for a stang. Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Oct 11, 2002 | 09:43 PM
FORDNUTTZ's Avatar
FORDNUTTZ
U joint problems?
pull the yoke off the trans and the t case and inspect then good
also while haveing those out
check the barings for loosness on the out shaft of thr trans and the in on the t case
ALSO check and see if your t case is loose ( i threw some safts because of this before)
tighten up all bolts and brace
Old Oct 12, 2002 | 07:24 AM
Fordman7780
U joint problems?
The middle shaft is not effected by a lift unless the transfer case is dropped and mine is not
i have pulled both yokes of and clean and inspected them and checked the bearings and put new seals in about 4 months ago and since then I have gone threw two U joints one lasted two days and I broke it and the ear of the drive shaft slip yoke will I was truck pulling so it has a knew slip yoke on it then I put a rockwell u joint in it and pulled three more times with know breaks or know problems until two days ago i heard a noise and checked the u joint and it is bad again it has about a 1000 miles on it and some I was only getting 300-500 miles Do you think truck pulling could be part of the problem
