Plug on driver side
Old Apr 28, 2009 | 10:28 PM
jefxxo's Avatar
jefxxo
Plug on driver side
On the driver side in the wheel well I have a Plug. It's blocked off. Dont know how many pins it has. Any ideas to what this is? F250 Diesel 4x4.
Old Apr 28, 2009 | 10:44 PM
quicklook2's Avatar
quicklook2
you have 2 wheel wells on drivers side.
want to share which one you are referring to?
Old Apr 29, 2009 | 11:18 PM
jefxxo's Avatar
jefxxo
In the front, just behind the bumper by the frame.
Old Apr 29, 2009 | 11:29 PM
HrdDrv's Avatar
HrdDrv
Why am I thinking a 110v plug-in for the block heater?
Old Apr 30, 2009 | 02:34 PM
subford's Avatar
subford
If it is in between the Fuse box and the firewall:
It is for a truck with the towing package.
I plugs into the plug going to the two aux relays that mount beside the main fuse box.
Need a photo of one with and one without the aux relays?
If it is near the radiator support by the headlight then it is for DRL.
Old Apr 30, 2009 | 08:59 PM
jefxxo's Avatar
jefxxo
I know that wire, I used it this winter. IT is on the passenger side.
Old Apr 30, 2009 | 09:05 PM
jefxxo's Avatar
jefxxo
Ok just looked at it. its on front of the last body mount by the frame. It has 7 wires going into it.
Old Apr 30, 2009 | 09:13 PM
subford's Avatar
subford
What are the wire colors?
Old May 1, 2009 | 12:42 AM
HrdDrv's Avatar
HrdDrv
Aint the block heater. (Deduct 4 points and move game piece back to Duh.)
Old May 1, 2009 | 05:25 AM
BigSix1's Avatar
BigSix1
Why the snark? (I'd try to ignore it, but it's not the first time....)
Is there any chance that there was a stock (i.e., by FoMoCo) plug hanging out in the rear wheel well? I'm asking because I don't know, and you probably do. Hence my question about "snark."
I'm not trying to start something--I'm just asking if there's a reason for the tone, since I come here to either get help or give help, but also to r-e-l-a-x. Snark is not conducive to the latter.
Thanks.
BigSix
Old May 1, 2009 | 07:07 AM
subford's Avatar
subford
I did not see this post.
That would be the DRL plug.
Old May 1, 2009 | 08:30 PM
jefxxo's Avatar
jefxxo
I wonder if that is the toggle under the steering column. hmmm
mybigredford
Nov 5, 2014 07:03 PM
TJK1
Apr 9, 2012 09:18 PM
paker
1997 - 2003 F150
Feb 28, 2011 07:07 AM
xbwfo
Modular V8 (4.6L, 5.4L)
Mar 11, 2003 02:41 PM
