5.4 plug change ?
Old Feb 2, 2003 | 01:03 PM
xbwfo's Avatar
xbwfo
5.4 plug change ?
Just pulled the driver's side coils. They are different inside the boot. Where the top of the plug meets the contact inside the boot, the passenger side coils have a flat metal surface which touches the plug. On the driver's side the coils only have a spring which has tightly wound coils at the end of it which makes contact with the plug.
Is this normal? Is a part missing from my driver's side coils?
Or
Did Ford just use 2 different coil types in my truck?
Old Feb 2, 2003 | 01:13 PM
xbwfo's Avatar
xbwfo
5.4 plug change ?
Old Feb 9, 2003 | 10:35 AM
krane operator's Avatar
krane operator
5.4 plug change ?
When I changed plugs on my 99 5.4 super duty I noticed mine where all the same . Coiled wire where boot is and flat where plug touches.
Old Feb 9, 2003 | 03:13 PM
xbwfo's Avatar
xbwfo
5.4 plug change ?
Thanks krane
All my passenger side coils are like yours. All my drivers side coils have NO flat surface to meet the top of the plug, just the open end of the spring inside the boot.
Is a part missing???
Old Feb 10, 2003 | 02:20 PM
nonamenoname88's Avatar
nonamenoname88
5.4 plug change ?
Is there a way of testing them w/out wetting your shorts? Check Ohm them or is there a tester?
Old Feb 28, 2003 | 09:21 AM
kwilliams's Avatar
kwilliams
5.4 plug change ?
I don't know what year your truck is, probably a late 99 or 2000. I have a 99 and have had to replace some of the coils. The original coils have a flat plate at the bottom that touches the plug like your passenger side. The replaced coil had the spring type on it. I believe that it is a newer version of the coils. Also the original coil has a kind of grey label on top. The replaced coil has kind of a neon green label. I guess ford was just using the last of the old type when your truck was made. As far as testing them, yes if you get a manual for the truck it tells you what the ohm should be and how to do it.
Old Feb 28, 2003 | 06:52 PM
xbwfo's Avatar
xbwfo
5.4 plug change ?
Thanks kwilliams, looks like some work was done on my truck before I got it.
Old Mar 11, 2003 | 02:41 PM
StevePA's Avatar
StevePA
5.4 plug change ?
Just bought a replacement coil today..... has the "spring" connection in it. It is from Autozone and a "Wells" brand.
RL7
1997 - 2003 F150
25
Jan 6, 2025 02:15 AM
Jose A.
Aerostar
Apr 11, 2014 12:35 PM
thunderbird1986
Modular V8 (4.6L, 5.4L)
Dec 7, 2013 05:48 AM
maxexn
Feb 19, 2012 05:08 PM
wchain
Jun 12, 2007 02:01 PM
