Jerky windshield wipers
My windshield wipers, mostly the drivers side do more of a shudder back and forth instead of a smooth slide.
I am guessing this is bushings in the linkage being worn?
Has anyone done this project. I see plenty of videos for changing the motor itself, but none for the bushings on this body style.
How new are the blades? How clean is the glass?
I find new blades work smooth and wipe great. Then a few months later, it skips and shutters horrible. The strange thing is it is always the drivers side. Nearly NEVER the passenger side.
Is it the window shape? I have change arms around, even got a new FOMOCO arm and still shutters on the drivers side.
I've had this issue a few times and once just recently. It did seem to always be the driver side. Other than fresh good blades and a clean windshield, the arm may not allow the blade to rest perpendicular to the glass. You can give the arm a little twist with an adjustable wrench or pliers. This is what I had to do.
I just put new blades on annually. Winter blades early Dec, summer blades early spring.
Its going to be raining here for the next 3 days. I'll go get a new set of blade today and see what happens. If it keeps it up, I'll get some video of how it looks when its acting up. This is more than a shutter or skipping, its and actual jerking back and forth as it sweeps across the windshield.
I just had a new windshield installed and new wipers too and had the screech noise when the blade just starts off of the bottom when there isn't a lot of water on glass.
I used a crescent wrench on the arm just behind where the blade attaches and gave a little twist to slightly bend the arm.
The screech disappeared from the lift off, but then I developed a chatter on the way down.
Took crescent wrench to it and undid some of the initial twist and they now seem to work great.
I think it is about finding that sweet spot...a happy medium if you will.
Look at the blade to the glass orientation. Like said up there^^^^^ the blade should be at 90 degrees to glass when at rest and slightly lifted from surface.
I remembered I have slow mo vid ability. Here it is with the old blades showing how the arm starts and stops. New blades helped quite a bit, but I am still thinking that the bushings might need some attention soon.
Also, notice how the passenger arm takes off to go back down before the drivers side.
dancraig
05-22-2013 09:41 PM
