difference between 150 and 250 frames?
Old Apr 29, 2009 | 09:50 PM
goodB0Y's Avatar
goodB0Y
Originally Posted by Jermafenser
So that's why my F350 sits higher in the rear over the F250HD. Thought it had heavier springs - that sucks.
What about the front? Are they also the same between a F250HD & a F350?
All the F250HD had the TTB front axle... and I think they all had the D50 but I'm not sure and they might have had the D44. The difference in height comes from the reverse arch of the front springs and the larger rear blocks.
Old Apr 29, 2009 | 09:51 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
An F250HD has a leaf-sprung Dana 50 TTB. F350s have the Dana 60 solid axle front end. The springs are also different, the F250 uses springs with either almost no arch or a slight negative arch. The F350 uses springs with positive arch.
Old Apr 29, 2009 | 10:51 PM
Jermafenser's Avatar
Jermafenser
Thanks! Yes, my F350 with the front monobeam axle has the springs arched positively, slightly. At least I think it is. Are those the same springs as the famous AAL that is popular for front-end spring swaps?
Old Apr 30, 2009 | 09:06 AM
77bigblock's Avatar
77bigblock
According to my shop manual, F250HD's never had a 300 or 302 in them. 73-79 and 80-86 were available with the 300 and 302 in a 3/4 or 1 ton chasis, but I'm pretty sure that stopped in 87. If a F250HD has a 300 or 302, it was put in there by somebody.
Old Apr 30, 2009 | 09:21 AM
2001LSV65SPD's Avatar
2001LSV65SPD
+1 My 250HD has the D50 front with the negative arch springs and a 351.
What are the main differences in the frame itself?
Old Apr 30, 2009 | 12:48 PM
preppypyro's Avatar
preppypyro
Originally Posted by jello
Is there any difference between F-150 2wd and F-250 2wd frames?
Will all the 8lug parts bolt to the 1/2 ton?
Are the F-150 I-beams the same as the F-250 where you can just swap the knuckles and brakes or do you have to swap the I-beams over and bolt them to the f-150 crossmember?
Im curious to why you were asking. I was just researching the same thing.
My plan was to make my reg cab shortbox 2 wheel drive, into a 4 wheel drive. I have a few cheap f250's lined up, and I was just researching to see if I could essentially take off all of the suspension from the f250 and bolt it onto the f150 frame, diffs and everything, get some driveshafts made and have a reg cab shortbox f250. (not like I would use it as one, but it would be neat to have it heavier duty, and have 8 bolt rims on it!)
Old Apr 30, 2009 | 01:52 PM
jello's Avatar
jello
Well
I want to do a reg cab short box 92-96 style 2wd with a 6.0.
If the F150 frame can handle it I'd put it in that and then just bolt up stronger drivetrain (8lug).
If the F150 frame can't handle it I can get a F250 and shorten the frame for a short box.
I found a complete super duty for engine/trans/wiring.
Old Apr 30, 2009 | 04:02 PM
aic's Avatar
aic
sounds like a beast is a brewin!
Old Apr 30, 2009 | 04:50 PM
preppypyro's Avatar
preppypyro
That thing will be wild man, totally insane!
94 F250 supercab
26
Dec 23, 2011 03:25 PM
7.3bo-ti-etr
17
Feb 5, 2010 01:44 PM
tankrsc
Sep 24, 2008 07:39 PM
Race8100
Dec 19, 2007 01:14 AM
lightningmatt
Feb 3, 2007 01:55 PM
