Help!!!Dangerous front end issue.....
Old Apr 29, 2009 | 11:57 AM
caleb90's Avatar
caleb90
Temporarily Deactivated
I just got done checking every thing...Every thing is tight ball joints wheel bearing pitman arm tie rods iner and outer...I took it for a drive after i did this and locked the hud on the side with the bad ujoint,and it did what it has been doing..Also when i locked the hub in the cap was trying to come off so i think i have a bad hub...Im going to tear it down tonight and replace the ujoint and check every thing out better...
Originally Posted by Yougotthehit
You my friend have the "Death Wobble" ask any jeep guy and he will tell you what it is.
Basically your front end is worn out and when you hit a bump good enough on one tire it will cause the steering wheel to shake vigorously. The only way to stop it is to jerk the wheel hard one way or the other. Bring your truck in and get a front end inspected they will tell you your pitman arm, tierods are bad.
Old Apr 29, 2009 | 01:30 PM
cjcocn's Avatar
cjcocn
If it turns out to be your u-joint freezing up it may have put some strain on the inboard needle bearing (at the back of the wheel bearing unit). Have a good lock at those needle bearings and also on the corresponding spot on the axle stub where the needle bearings ride.
EDIT: That may also be why your locking hub seems to want to pop off (misalignment of the axle stub vs hub splines).
Good luck with the tear down, thanks for keeping us informed, and post up your findings - it's always good to hear the cause and solutions in case we run into a similar situation.
Old Apr 29, 2009 | 01:49 PM
joeyd61's Avatar
joeyd61
Take a look at the stearing stableizer....that was my problem
Old Apr 29, 2009 | 01:52 PM
caleb90's Avatar
caleb90
hmmm..i didnt think of that,good call..That might also be a culpret in my problem seing how the bottom side of my stabalizer is flatend out from 4wheeling with my truck..
Old Apr 29, 2009 | 09:02 PM
caleb90's Avatar
caleb90
Well i got her done,culpret was a very badly frozen u joint...When i took the hub off the neadle bearing was in great condition...must be the fozen u joint was puttine a lot of pressure on the hub making it lock till i straiten the tire...but she is all better now..thanks for the help...
Old Apr 29, 2009 | 10:08 PM
zx250's Avatar
zx250
Of the next Riffraff East
Good deal, glad you found it at thanks for updating the thread.
Old Apr 30, 2009 | 08:07 AM
Technocrsr's Avatar
Technocrsr
Great you have it fixed, can you tell us what you had to take apart, to look for and replace to fix this?
I'm getting a noice to at about 25-30 miles on up and sometimes a weird feeling in the steering wheel after a turn.
Thanks
Old Apr 30, 2009 | 11:27 AM
caleb90's Avatar
caleb90
you gotta take the tire,caliper caliper braket,hub,and wheel bearing out to do this...
Thanks
Old Apr 30, 2009 | 11:39 AM
cjcocn's Avatar
cjcocn
Thanks
If you read <a href="https://www.ford-trucks.com/forums/354091-how-to-replace-your-super-duty-ball-joints.html">this thread</a> you should get all of the info that you need.
<a href="http://www.guzzle7pt3.com/nblube.php">This write-up</a> should also prove useful to you.
HTH
Old May 7, 2009 | 07:11 PM
run1d10t's Avatar
run1d10t
i have a f250 and received a letter from ford regarding front end shimmy. didn't think to much of it till i hit a bump at 65mph. in their letter they call it SEVERE vibration. i call it VIOLENT. They know there is a problem. taking my truck in friday to dealer.
Old May 7, 2009 | 09:01 PM
Smokin''s Avatar
Smokin'
Smokin
This has been a very interesting and informative thread.
Glad you got it fixed, Caleb.
greenman0013
Feb 20, 2017 08:32 PM
Marc150
1997 - 2003 F150
Dec 31, 2010 11:09 AM
BroncoPimp94
Feb 9, 2010 06:45 PM
PS2001
Feb 1, 2010 08:53 AM
richlub
Offroad & 4x4
Jan 24, 2007 11:20 PM
