GTP38R's Are Here!!!
Old Apr 28, 2009 | 03:58 PM
big poppa's Avatar
big poppa
Appreciate it fellas, really do. I will document everything, I love pics too and will let you know what kind of visual no#'s before and after..
Old Apr 28, 2009 | 04:56 PM
ron's power stroke's Avatar
ron's power stroke
i see your off line Mike..cuddling or installing???
congrats..your going to love the new toy...it does looks new..nice score..
Old Apr 28, 2009 | 06:02 PM
big poppa's Avatar
big poppa
Back on, no installing, just cuddling ............the turbo, lol. J-K. Thanks Ron, i'll PM yaa later if your avail??
Old Apr 28, 2009 | 07:20 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
There's a couple of things I think you'll want to do while you've got it on the bench.
First, the plug in the top of the center section housing either is leaking or will leak. Do yourself a favor and pull that plug and put some thread sealant on it before you install it on the truck...... If it hasn't already been done.
Also, with stock sticks you're going to loose a lot of boost with the 38R. I'd suggest you go ahead and crank the waste gate down as far as you can before hand as well.
Old Apr 28, 2009 | 07:31 PM
big poppa's Avatar
big poppa
Will do Scott, I'll check the plug out tonite and do that and the wastegate. Roland and I think Ron made that point also, crank it all the way down, gotya thanks. While I got you, Bob hooked me up with those Viton sleaves to replace back by the turbo, he said the turbo cooks them, where do they go???
Old Apr 28, 2009 | 07:38 PM
Izzy351's Avatar
Izzy351
Do even need the waste gate connected at all with stock sticks?? I doubt you'll drive it hard enough to the point where you need to bleed off drive pressure....
Old Apr 28, 2009 | 07:45 PM
zx250's Avatar
zx250
Of the next Riffraff East
I'm still jealous!
Old Apr 28, 2009 | 07:48 PM
ron's power stroke
them oring go on the 1/4" fuel feed line..back of pasanger head.(the one that cooks).front of driver's head..the other 2 ends are on the bowl side by side passanger side )..put the oring on..tighten nut by hand till it hits the oring..with a wrench give it about a 1/2 turn..do not tighten tight..it will spoil the oring..
Old Apr 28, 2009 | 08:23 PM
big poppa's Avatar
big poppa
Originally Posted by zx250
I'm still jealous!
Don't be brother, I'll help find you a deal soon..
Will do, thanks Ron..
Old Apr 28, 2009 | 08:27 PM
zx250's Avatar
zx250
Thanks Bro, I've been investing all my extra cash in modifying my gun safes with interior accessories while I am still allowed. Not much extra for the truck right now.
Old Apr 28, 2009 | 08:46 PM
cookie88's Avatar
cookie88
FTE Emeritus
Not at all. I have mine pulled shut with a chain and turnbuckle. Stock sticks will only push 26-28 psi with the BB.
Old Apr 28, 2009 | 09:03 PM
big poppa's Avatar
big poppa
Well, I just did the bolt with some sealant and pulled the wastegate as far as it would go, anything else or am I ready to roll???
Old Apr 28, 2009 | 09:09 PM
  #28
Tenn01PSD350's Avatar
Tenn01PSD350
Hmmmm, what's a wastegate?
Seriously though, it is like a governor for crappy air. You will loose some boost with the 38R all things being equal, but make mo powa.
Old Apr 28, 2009 | 09:12 PM
  #29
Adam0331's Avatar
Adam0331
That's awesome Mike. Looks brand spankin new.
Old Apr 28, 2009 | 09:57 PM
  #30
Stewart_H's Avatar
Stewart_H
Sweet!
Certainly looks as described! Good to see "buyer beware" didn't apply here!
Stewart
