Seriously though, it is like a governor for crappy air. You will loose some boost with the 38R all things being equal, but make mo powa.
My man, looking foward to it. Hope it bolts up right the first time Mike, we'll see...
Originally Posted by Adam0331
That's awesome Mike. Looks brand spankin new.
Unreal, still in awe..
Originally Posted by Stewart_H
Sweet!
Certainly looks as described! Good to see "buyer beware" didn't apply here!
Stewart
The seller Manny told me before he shipped it to call him when I got it and call him and asked if i,m satisfied with it. I called him 3 hours ago and told him the turbo looked great, just like he discribed.. Told me he was happy that I was satisfied and he'll be on FTE when he can soon, he's a part time cop and trying to grab every job to keep his electrical business afloat, I wish him all the luck. He likes this site, very nice people and great info.. Awesome all the way around..
I think you're ready. Are you going to gut the EBPV before you swap it over, or just leave it stock?
Good deal, looking foward to it.. I was going to leave it stock, gets pretty cold up here in the winter and that helps but if I decided to do that, can I get rid of the EBP tube that runs along the front of the motor down to the exhaust header?? Is that conected in any way Scott?? Just seen Mike's post above, subscribing, is it???
If you get rid of the EBV sensor and tube you'll have to get one of those plugs that fools it into thinking it's still there. To get rid of the actuator itself you physically remove it from the housing and disconnect the electrical connector at the base of the pedestal.
Mike's post was poking fun at me from when I had the heads off. I plugged the wrong harness into the IPR, which is a mistake that happened because I don't have an EBPV anymore and I got the two plugs confused.....so no, it isn't.
Is that the plug you are supposed to put oil in before you crank it up the first time?
I turned the turbo upside down and poured a little oil in the inlet port, then gave the wheel a few spins. My idea, not theirs. I put the turbo on and let it idle several minutes per Garrett's instruction. After it gets to operating temperature, drive it "normally'', depending on your definition of "normal". I'm just going by the instruction sheet.
That's funny Scott, but not what I was talking about. I was told to put oil in the top of the center cartridge before starting it up the first time. This is supposed to ensure lube and not having a dry spin up until oil gets there on first start.
Gotcha'....My apologies. I'd never heard of pre-oiling the center section.....so my mind wandered to something I was familiar with.
IMVHO pre-oiling is a non issue. Ball bearings will "break in" but you pretty much have to be spinning it full boogie under a load to get it to wear into the journals. Plus it will be at pressure within about five seconds of turning the key, so a little film of oil really isn't going to help, or hurt, anything.
It's one of those situations that if it gives one piece of mind to do, then do it. Personally I prefer a clean, oil free mating surface.
I prefer a clean surface too. I was talking about putting it in there after it was mounted and everything was set to start. Kinda the last thing before turning the key. Not sure how critical it is, just what I was told, and I don't even remember where I got it?????
I had one of the early 38r's that came with no sealant of any kind on the plug. If I remember correctly after I started the truck, by the time I got out of the cab and walked around to leak check it there was already a leak there. I'm not sure exactly by what route the LPOP feeds the turbo, but the flow there happens very quickly.
Well, my wife is home, and she's doing fine now, thanks for the well wishes as always. I'll still be taking care of everything so she can rest up completely and she said to me on the ride home "You can't wait to put that turbo in, can you" And I said. So between taking care of mom, turbo time...I'll start early tomorrow morning tearing everything down so when Adam comes down Sat, it will be alot easier.
