'79 F100...Broken dvr side leaf spring pack.
Old Apr 28, 2009 | 08:16 AM
FTE Trigger's Avatar
FTE Trigger
I'm still assisting my nephew getting his F100 "road-ready". So after changing brakes, shocks and tires we've discovered that he also has a broken leaf spring pack on the driver side.
My question is: Would there be a another year/model leaf spring pack that would bolt in under his '79? It seems I'm having some difficulty finding a local salvage yard that has a complete pack to replace his broken one with.
Specs:
'79 F100; 5.0L 302; 2wd, SB-w/ reg. cab, Auto tranny.
Old Apr 28, 2009 | 04:01 PM
73FOMO's Avatar
73FOMO
I would think that would be an easy item to find at salvage. Any '73-'79 pack 2wd pack should work.
Old Apr 28, 2009 | 05:31 PM
Jermafenser's Avatar
Jermafenser
Why?
30 years old springs are TIRED!
Buy a new set instead and feel the change in ride tremendously.
Old Apr 28, 2009 | 08:21 PM
FTE Trigger
Around here, most of the salvage yards seem to thin out vehicles that are 15+y/o
Originally Posted by Jermafenser
Why?
This made me think of another question... with his "Tired" suspension...
I noticed what seemed to be a coil spring on the passenger side (Iirc), but there is not one under the driver side- Does this sound factory-OEM?
It seems to be mounted to the same planes as the leaf springs are (also Iirc)
When I see my nephew (hopefully tomorrow) I'll snag a pic of it and post.
I'll look for some new leaf springs too. Any suggestions?
On edit: I found this...http://www.generalspringkc.com/index...parent=76&pg=1
Old Apr 28, 2009 | 10:06 PM
Jermafenser
On edit: I found this...1973 - 1979 F100 / F150 Leaf Springs
The driver's side coil spring is missing?! That is dangerous. There's no such thing as having one coil on only one side. Both sides must have coils in front. I'd get new coils (both) in the front if one went missing!
The 1450 lb springs total to 2900 lbs, which is correct for a F100 with a 9".
Haven't bought leaf springs before...but I'd go with brand names.
Old Apr 29, 2009 | 05:58 AM
FTE Trigger
REAR... is where this spring is (and its missing counter part?). Iirc, it mounts to the same surfaces/planes as the leaf springs. I hope I can confirm this today.
...Nothing wrong with the front.
Old Apr 29, 2009 | 06:00 AM
nutfarmii's Avatar
nutfarmii
Rich,
Take a look at page 66 of the PDF file from BRONCO Graveyard one of our supporters. "
Leaf springs.
23260 Rear Leafs Stock 78-79 Br, 73-79 Pu
23262 Rear Leafs 3½” Lift 78-79 Br, 73-79 Pu
23264 Rear Leaf 5½” Lift 78-79 Br, 73-79 Pu
23258 Rear Leafs 77½-79 F-250 3” Lift
$230
$329
$325
$339
Prices are in the same order as the part numbers.
Good to see you online again, we are doing the same with James 78 F100.
Cya
Old Apr 29, 2009 | 06:01 AM
nutfarmii's Avatar
nutfarmii
Hit enter to quick dand,
Coil Spring.
23200 Coil Spring Stock
23202 Coil Spring 2” Lift
23204 Coil Spring 4”-4½” Lift
23206 Coil Spring 6”-6½” Lift
23208 Coil Spring 8½”-9” Lift
$90
$125
$125
$145
$179
These coil springs are offered in a variety of sizes and
offer excellent ride quality, control and longevity. Fits
1973-79 Pick-ups and 1978-79 Broncos (sold in pairs).
Same page for the coil springs, and I agree with Chad, one spring WTF, there should be 2 one each side, and if there are springs in the rear it probably had a lift kit put on, again go to BRONCO Graveyard site. (there still should be one per side, and whoever did it didn't do it right coil springs are for the front)
Old Apr 29, 2009 | 08:16 AM
73FOMO's Avatar
73FOMO
I don't know any 2wd's that have a coil spring in the rear. Maybe it was some type of overload spring. I would replace the leaf pack and yank the coil spring(s). We still have several old salvage yards around here with the leaf packs, but If you are willing spend $200-300, go for new.
Old Apr 29, 2009 | 12:11 PM
justforkicks's Avatar
justforkicks
coils in the rear are overloads... that's what were under my ranger when it was bought a few years ago. as for springs, any 2wd w/the same width from 73-79 will work
Old Apr 29, 2009 | 01:07 PM
FTE Trigger
Thanks!!
This has me suspecting that a PO had a killer payload that wiped out the driver side -rear- coil spring and leaf spring pack.
Old Apr 29, 2009 | 01:14 PM
Jermafenser
Oh, okay...in that case, I'd just remove the overloads entirely as it's no longer 100% functional. It can't be good to drive with one coil missing...
It's easy to overload a F100 as it's the lightest series.
Old Apr 29, 2009 | 01:20 PM
FTE Trigger
I felt the same way about it.
Thanks for the search Marc. Jeff's was one of the ones I first dug into last night about finding a set. Everyone else seems to have the install/bushing kits.
Bakers seems to have a few sets laying around. Until we get a full "refurbish" budget in the works we're going to settle for "pre-owned".
Aussie_F_trucker
Feb 1, 2013 09:45 PM
clhart426
Dec 29, 2009 06:20 PM
RacerLT250R
Feb 3, 2009 10:01 AM
864x4
Dec 18, 2006 12:48 PM
72_ford
Apr 5, 2002 12:33 PM
