7.3 injectors
Old Apr 27, 2009 | 08:30 PM
johndeere01's Avatar
johndeere01
7.3 injectors
hello i have a 2000 f-350 powerstroke and i want to put bigger injectors in or something with more horsepower. in the second owner and the guy before put a chip in from some where i dont know the name of the chip. any ideas are great.
thanks.
Old Apr 27, 2009 | 08:41 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
You need to slow down and tell us all about your truck and the mods you have right now. You don't just put injectors without some supporting mods. Let us know, then we can help you go in the right direction.
Old Apr 27, 2009 | 08:48 PM
F350-6's Avatar
F350-6
Welcome to FTE. As Rick said, you need the proper supporting mods first. Besides, with these computer controlled engines, you'll get more out of a custom chip than you will by dropping in different injectors. You can always add the bigger injectors later and have the chip tweaked to run them.
A custom chip like one from DP will run circles around an off the shelf product like Edge, Diablo, Superchips, etc.
Old Apr 27, 2009 | 08:50 PM
johndeere01
well first off its a crew cab dually. i pull a lot of trailers with horses all the time. it has a 5 inch flowermaster on it and it has a chip but i dont know what kind on it i will try to contact the guy. but other then that its stock i has 108000 on it i just want more hp pulling trailers
Old Apr 27, 2009 | 08:55 PM
F350-6's Avatar
F350-6
Upgrade your intake, add a set of gauges if you don't have them already, then check out someone like DP-Tuner.com and their tow tunes. How many horses are you pulling, and is it up and down the mountains?
Old Apr 27, 2009 | 09:03 PM
johndeere01
what kind of intake? ok i will check DP tuner out. im pulling two draft horses with a wagon. the trailer is 32 foot on the floor with no room in the trailer. planing on gitting a bigger trailer to.
Old Apr 27, 2009 | 09:11 PM
F350-6's Avatar
F350-6
The cheap version for an intake is the 6637, which is a Wix 546637 filter. You can also look into an AFE stage 2, or the Ford AIS intake. Don't forget the gauges. You'll want to monitor boost pressure, tranny temps and EGT's to make sure you don't hurt anything. Something else to consider is a shift kit to firm up the shifts and help the tranny last a little longer.
Rick has the DP in his truck and recently upgraded his injectors. With the combination of those 2, he can break the back wheels loose on his dually while cruising around. If he doesn't chime back in tonight, he'll have more input in the morning.
Old Apr 27, 2009 | 09:15 PM
johndeere01
ok thanks i will look in to all that stuff. i just want to do i right the first time if u know what i mean.
Old Apr 27, 2009 | 09:38 PM
miller_feed
Ok, doing it right the first time is a good idea. But you need to listen to what we are saying, lots of these guys have done the trial and error for you, so you don't make the same mistake and spend money on things you don't need. Chris knows his chit, you need a good intake, you have the exhaust, but gauges are a must. After you get these things done, then we can talk chip and valve body. Once you get to that point, you may not want to do turbo and injectors, because your truck will pull like a beast. With the mods I have right now, I can pull the beast.
Don't get in a hurry, do these as you can afford them, just don't buy anything till you come on here and ask us. You will not go wrong here.
EDIT: Yeah, I can putt alone at 15-20 mph, stump the pedal and break the tires loose on my dually. Don't ask what happens when I put it in 4x4 and boost to 20# and let the brake go.
Old Apr 27, 2009 | 09:39 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
Clay is having a sale on DP. Check it out.
https://www.ford-trucks.com/forums/8...uner-sale.html
Old Apr 27, 2009 | 09:45 PM
jeff7825's Avatar
jeff7825
I agree with everything else that has already been said. One more thing about injectors is that you have to have custom tuning to run them anyway, so you will need to get a custom chip at some point anyhow.
Old Apr 27, 2009 | 10:03 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Well i wanna know lol
Old Apr 28, 2009 | 02:21 PM
johndeere01
im looking at gagues now what do u have in your truck? because i dont want to buy anything to chep gauges.
Old Apr 28, 2009 | 02:31 PM
superduty4x4's Avatar
superduty4x4
Isspro, Autometer, and Dipricol are the best out there for gauges. I have and prefer the Isspros myself. If you can swing it, get the Performax line.
Old Apr 28, 2009 | 02:48 PM
miller_feed
Hey, Will. lol. I took Chad for a ride when we did his turbo rebuild. He said, man, I know you lifted the front wheel off the ground. . Better have nothing in the cubby holes on the dash, they end up in the back seat.
