Amsoil
Old Apr 30, 2009 | 05:48 AM
Djack04F150XL's Avatar
Djack04F150XL
From previous experience if the oil is clean after 3 to 5K it usually is not cleaning the engine, causing sludge buildup. Does Amsoil and the Amsoil filter remove sludge and other deposits? If it is that efficient I am all for it, but I would like to see some real test data.
Old Apr 30, 2009 | 06:36 AM
ChargersFanInCO's Avatar
ChargersFanInCO
Well, hopefully my truck doesn't have sludge buildup in her. She only has 4300 miles on her. That's why my oil is clean...lol
Old Apr 30, 2009 | 06:37 AM
ChargersFanInCO
another Amsoil question: Do you change the filter before 25k?
Old Apr 30, 2009 | 05:42 PM
wildcard30's Avatar
wildcard30
I use Amsoil in my Harleys. And it works very well. I use the 20W50 for V-Twins. It helps the motor run cooler.
I have never used it my cars/trucks...
But I do use Motorcraft 5W20 oil and filters in my Fords. I traded in a 2001 Focus in January of this year on a new 2009 Focus.
Miles on the 2001 at trade-in, 362,718
Not bad for using just good old Motorcraft, Ford recommended, motor oil.
I can change my oil in 20 minutes. It also gives me a chance to look around under the vehicle for other problems.
As with all the other oil threads on this forum, you may have asked about Amsoil, but you will get input about other products.
Old Apr 30, 2009 | 07:57 PM
magnet1's Avatar
magnet1
The oil that comes out after 25,000 miles is definetley darker, but the viscosity or the feel of it between your fingers is what doesen't change. All oils when drained, pour like water with no lubrication properties left at all; Amsoil comes out like it went in. The new filters they have now are good for 25,000 miles, same as the oil. It used to be a filter every 10,000 miles, but new filters have been designed. If you are switching from standard motor oil, I would change the first filter at 10,000 because its going to pull dirt out of your motor. The reason it doesn't create sledge is because the base of the oil doesen't use a parafin wax base like every other oil out there including Mobil1. Its all together a different setup and process.
Old Jun 3, 2009 | 07:21 PM
fnx4wheeler's Avatar
fnx4wheeler
You use the same filter EA#### (Amsoil made by Donaldson I believe) for 25,000 miles. It filters down to something like 3 microns vs the usual 10.
Old Jun 3, 2009 | 09:04 PM
klook's Avatar
klook
I was going to throw some stories in there but I'll just say I'm with the magnet on this issue. I have my own "proof" and a good number of old guy naysayers. I will say that the last car my wife had blew a turbo after we traded it in. It had only 35,000 miles and had nothing but Mobil 1 in it since new. The salesman told me that it was sludged up. I will not use anything but Amsoil from now on.
Kevin
Old Jun 5, 2009 | 12:01 PM
Luvmy150's Avatar
Luvmy150
Ok, I'm sold. The intial hit is going to be large (need to do motor, tranny and diff's), but well worth it.
Old Jun 5, 2009 | 06:34 PM
ShootinOK's Avatar
ShootinOK
Find an Amsoil dealer - the price is less than the "retail" catalog price. (it should be)
Ted928
2004 - 2008 F150
Jul 1, 2016 12:19 PM
natedowney
15
Nov 20, 2014 05:44 PM
derbyhunter5
Apr 28, 2011 09:19 AM
donybrk
2004 - 2008 F150
58
Jun 27, 2007 03:32 PM
BlackFX4Screw
2004 - 2008 F150
29
Apr 7, 2007 06:24 PM
