Sponsored by: Real Truck
Water in fuel sensor
Old Apr 27, 2009 | 02:59 PM
hawkeye07's Avatar
hawkeye07
I have a 2005 PS. The water in fuel won't go off. I have drained it 6 or 7 times and the fuel is clean. I have also replaced both filters. ( thanks to the awesome info given to me on changing the filter in the pump ) The sensor was changed about 2 yrs. ago. My guess s that it is bad again. How difficult is it to change myself.
Old Apr 27, 2009 | 03:37 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If it had a lot of water in it, you MAY have to replace filter more than twice! Drain it again, but realize that it may need a new filter again.
Old Apr 28, 2009 | 02:25 PM
Help I M Stuck's Avatar
Help I M Stuck
My 2005 did the same thing...drained the filter housing in the frame rail..wiped it out good..let it air out for a half hour..put new filters on. It was good to go after that.
Old Apr 28, 2009 | 02:48 PM
hawkeye07's Avatar
hawkeye07
Thanks I M I will try that. Also would it be possible to reuse the filter with the same O ring. I just changed them yesturday
Old Apr 28, 2009 | 02:51 PM
hawkeye07's Avatar
hawkeye07
Thanks BPofMD. Have you ever changed out the sensor and how much trouble is it to do it.
Old Apr 28, 2009 | 04:25 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I've been lucky...never had to do that.....I only buy fuel that needs tanks filled every other day or so....No water (usually) in those stations!
Nick 99
Dec 7, 2014 04:48 PM
mmenzies
Jan 31, 2013 09:21 PM
bduemig
13
Aug 16, 2010 03:17 PM
bearhugger
Oct 26, 2009 06:51 PM
lionsteve
Aug 26, 2008 09:31 PM
