94 Ignition Control Module Problem
Old Apr 27, 2009 | 10:31 AM
Jeff3298's Avatar
Jeff3298
I have a 94 F150 Super Cab 5.0.
It would not start so I had I shop look at it and they diagnosed on the test equipment that the ignition control module was not working and they replaced it.
A few days later it died again and they replaced it.
It lasted two weeks and it too failed yesterday.
They replaced it with motorcraft too.
What could be causing this part to blow, there must be something before/after that part that is causing it to blow out.
Any suggestions on what that might be?
Thanks for your help,
Jeff
Old Apr 27, 2009 | 11:31 AM
subford's Avatar
subford
I would doubt that there was anything wrong with any of the Modules.
My guess would be you have a bad "PIP" sensor inside the distributor.
By the way make sure they are replacing the ICM with a BLACK one and NOT a GRAY ICM.
Old Apr 27, 2009 | 11:43 AM
Jeff3298's Avatar
Jeff3298
They replaced it with the black one. I just talked to my mechnic and hed said there was a part in the distributor that he will replace today that is causing it to blow. Thanks for the confirmation, thats why I love this forum.
Jeff
Old Apr 27, 2009 | 11:58 AM
subford's Avatar
subford
Jeff
The PIP sensor is an off and on switch and would not cause the ICM to go bad. It does the job of the old Ignition Points or the pick-up in the older distributors.
By the way if the ICM had a date code of 4L18B it is on recall and Ford should replace it for free.
Location of the date code:
Old Jun 20, 2009 | 06:21 PM
F-7's Avatar
F-7
I just looked at mine it's gray did they also have a recall my truck has a stalling issue also
F-7's Avatar
F-7
I just looked at mine it's gray did they also have a recall my truck has a stalling issue also its an 88 f450 with a 460 Thanks
Old Jun 20, 2009 | 06:34 PM
subford's Avatar
subford
The above was for the remote mounted ICM.
Yes they had some bad ICM mounted on the distributor and they replaced them with some better updated ones.
But I would have thought yours would have been changed out years ago with the better ones.
Your problem sounds more like a PIP sensor then the ICM but it could be either.
Old Sep 9, 2010 | 08:11 PM
Fordman91's Avatar
Fordman91
stalling while driving
I am having the same problem with my truck that jeff was having. Just my truck usually starts right back up with a couple extra cranks than a normal start. Except for today. It took about 3 min or so to restart
Old Sep 10, 2010 | 08:40 AM
subford's Avatar
subford
Fordman91,
You may have a fuel check valve problem.
You should start a new thread.
websurfer
19
Feb 21, 2024 06:19 PM
Surfcop
13
Apr 9, 2015 12:08 PM
Grinder Man
Oct 10, 2014 09:35 AM
jeff2011
Sep 7, 2009 10:54 PM
Camphill
Sep 28, 2008 08:54 AM
