1992 f150 transfer case is leaking
09-10-2010, 07:35 AM
on
leaking atf where it bolts to tranny. do they make a gasket for it. seems it had silicone before but obviously didn't work too well.
Also can the rear mainshaft bearing be changed fron there without taking transmission apart???
thanks
09-10-2010, 08:36 AM
Its called a Extension Housing Gasket. And it is made, but made out of paper. I can't seem to find it, not in a kit.
As for the main???
09-10-2010, 08:39 AM
on
i hear the rear bearing making a noise might be because the fluid leaked out. but while i have it off i'd like to replace it.
09-10-2010, 08:45 AM
agw
09-13-2015 10:13 AM
donhclark
05-23-2003 01:11 PM
killer4x4
03-09-2001 06:49 AM
1992 ,
1993 ,
1996 ,
92 ,
96 ,
case ,
extender ,
f150 ,
fluid ,
ford ,
half ,
leak ,
leaking ,
problems ,
ton ,
transfer
