2002 Ranger lower ball joints
Old Apr 27, 2009 | 09:19 AM
jamesemery728's Avatar
jamesemery728
Any special tricks I need to know about replacing just the lower ball joints on a 2002 ranger 2WD. Can someone list the procedure steps for me.
Old Apr 28, 2009 | 10:19 AM
Rockledge's Avatar
Rockledge
As far as I know, the tricks for a '98 still work on the newer models:
https://www.ford-trucks.com/forums/1...ll-joints.html
Old Apr 28, 2009 | 12:52 PM
jamesemery728
thank you
Thank you Rockledge. I have done cars before so I have all the tools but just never tackled the truck. Thanks for telling me how to do the job rather than how difficult it was going to be, and how many tools I was going to need, etc, etc, etc. Now I just have to "get-er-done".
Old Apr 28, 2009 | 12:59 PM
Rockledge's Avatar
Rockledge
Good luck with the repair, and if you figure out some tips yourself, make sure to pass them along.
Old Apr 30, 2009 | 02:10 PM
jamesemery728
did the lowers today
Did the lower ball joints on my 2002 2-wheel drive Ranger today. The hardest part was separating the upper ball joint from the upper control arm pinch bolt. Thank goodness for PB-Blaster. Had to use two pickle forks, one was the big ol hammer type and the other was in an air hammer. Placed one on top of the other to span the large gap to get them apart. Destroyed the rubber boot in the process but fortunately Auto Zone sells just the boots so I did not have to repace the uppers, just the boots. I think that I could replace the uppers with my 20-ton press but you would still have to take out the control arm due to lack of clearance to use the C-clamp style press. Thanks for the help, as usual the hardest part of any project is just getting started.
Old May 1, 2009 | 08:37 AM
Tomm's Avatar
Tomm
I was going to change my upper ball joints on my '98 2wd and found out that the amount of time I saved and the small added cost it was worth changing both upper control arms instead.
jchandler11
1997 - 2003 F150
19
Mar 15, 2017 07:27 PM
sjl2569
Dec 11, 2016 01:42 PM
Boss_358
Apr 8, 2016 09:37 AM
slidingdelta
Feb 21, 2011 03:32 PM
GreenBoonie
Apr 15, 2005 09:05 AM
