Sponsored by: Real Truck
Coolant smell when pulling
Old Apr 26, 2009 | 11:21 PM
doc898's Avatar
doc898
Hello All,
I have an 05 F350 with the 6.0L Powerstroke. When pulling my boat (6000lbs) I get a strong smell of coolant in the cab. I was told by a neighbour that my intercooler is shot. Any comments?? Could this be??
Thanks
Old Apr 26, 2009 | 11:29 PM
aldridgec's Avatar
aldridgec
Probably heads lifting and puking coolant.
A coolant smell would really have nothing to do with the intercooler on these trucks. Some vehicles use an air to water intercooler but I'm still not sure how that would cause a coolant smell only while pulling.
With your truck, the heads a probably only lifting under heavy load.
Old Apr 26, 2009 | 11:32 PM
BadDogPSD's Avatar
BadDogPSD
Originally Posted by doc898
Hello All,
Thanks
Probably not your intercooler. Do you notice the coolant smell at any other times? You may have a small leak that gets more pronounced when
your engine is working hard. Any sign of coolant in your oil? You may want to pressure test your system to check for leaks.
Old Apr 27, 2009 | 06:44 AM
adamss's Avatar
adamss
I had the same problem a month ago when I pulled my household goods (much heavier load than most SD driver would think of pulling, but that's another story) from mississippi to Montana. I took it to a local dealership and they charged me 100 bucks to find and fix the problem.
Diagnosis:
Radiator cap lost its "spring" tension. A freakin 10 dollar cap cost me 110 bucks out the door.
Check and see if there are white deposits around the cap area, around the overflow tank, and every else. This is a sign of a leak.
Good luck.
Old Apr 27, 2009 | 08:49 AM
doc898's Avatar
doc898
Thanks for the advice. I was under the hood last night and didn't notice any signs of coolant around the rad or anywhere else. I will have a better look today. I would be happy if it were the rad cap!!
If the heads are lifting under pressure and drawing in a bit of coolant, is this repairable by simply taking it to the dealer? Is there any major components to be replaced? The truck is still under engine warranty (thank god) and this should be covered.
Many thanks
Old Apr 28, 2009 | 02:28 PM
Help I M Stuck's Avatar
Help I M Stuck
get it to the shop ASAP!! That's signs of head gasket failure. TURST me..my 05 just did the same thing over the weeekend and is now sitting in the shop with a blown head gasket!!!
Old Apr 28, 2009 | 04:16 PM
F250Wheels's Avatar
F250Wheels
Have it checked out, A plugged oil cooler will do the same thing. The EGR cooler dosen't get enough water flow and that will boil the water in the EGR cooler and puke out the cap. My 2004 F250 did this.
Old Apr 28, 2009 | 04:20 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Both the above are true...soooo, it COULD be either problem....so long as it's still under warranty, get it to your dealer ASAP.
Old Apr 28, 2009 | 10:24 PM
doc898's Avatar
doc898
I took it to the dealer today. The service manager advised that the head lifting issue is very rare, in fact he's only seen two of them. The Rad bottle on the drivers side in front of the fire wall is the most common of problems. We removed the cap and sure enough, there was some white crusty stuff around the seal and down the threads. I am going to change the cap first as this is the cheapest fix, and the dealer can not get the truck in till next week, at which time I will be back home. Unfortunatly, I have to haul my 6000lb boat about 500miles to get there. Hope I make it!! Thanks for all the great info.
Old Apr 29, 2009 | 08:49 PM
aldridgec's Avatar
aldridgec
Very rare eh? It's just very expensive to fix. Radiator caps are cheap. Make sure it's fixed right and documented.
jim6liter
Dec 12, 2009 01:20 PM
DieselE
Nov 18, 2009 09:52 AM
Karl Keicher
May 27, 2008 08:35 AM
V10_Cougar
Modular V10 (6.8l)
20
Feb 23, 2007 05:12 PM
Nitrous
Oct 8, 2006 02:07 PM
