coolant smell
Old Dec 11, 2009 | 11:29 PM
jim6liter's Avatar
jim6liter
coolant smell
whenever I am pulling my trailer,and put the pedal down,I get a coolant smell in the cab.It's only when pulling and hammered.I don't seem to be losing any coolant.Any ideas?
Old Dec 12, 2009 | 06:56 AM
Maxium4x4's Avatar
Maxium4x4
Only about 2 places to look, EGR cooler and head gaskets. Might be just the start of head gasket while you are towing.
Old Dec 12, 2009 | 08:00 AM
janton01's Avatar
janton01
I got it pulling the boat last summer. Degas bottle puking. Ended up a plugged oil cooler letting very little coolant get to the egr cooler. Engine fan also running constantly under load. Replaced the oil cooler and egr, plugged the exhaust input end of the egr. No more problems with 5 k on it. Hope that is all you have going head gaskets are an expensive deal. Mine is un modified with only a coolant system filter.
Old Dec 12, 2009 | 08:50 AM
jim6liter's Avatar
jim6liter
There is no residue on the water bottle. Also no smoke thats noticeable.No smoke at startup either.My fan clutch went bad last year,I thought that was the problem.I replaced that clutch and the problem still exists.The fan seems to run alot more these days when pulling though.
Old Dec 12, 2009 | 01:20 PM
janton01's Avatar
janton01
On mine the fan was running because of the high oil temp. Now that the new cooler is in and working it almost never comes on. Hope your cooler is the problem and not head gaskets.
TJ Hensley
Feb 26, 2014 05:56 PM
DieselE
Nov 18, 2009 09:52 AM
doc898
Apr 29, 2009 08:49 PM
Karl Keicher
May 27, 2008 08:35 AM
miller502
Aug 4, 2007 11:33 PM
