bucking and jumping problem when accelerating!!
Old Oct 21, 2002 | 10:18 PM
jason9009's Avatar
jason9009
my 86 f150 bucks and jumps liek crazy whne i try to accelerate. i have to practicly hold my foot above the gas pedal to go and i cant get over 35 mph or it will buckand jump when i push the pedal down the slightest bit harder. Any ideas what thismight be?
Old Oct 24, 2002 | 09:35 PM
Polkat's Avatar
Polkat
Sounds like a busted motor mount (or tranny mount). If you can see the air cleaner while sitting in the cab with the hood up, start it with the emergency brake on and put it in gear (if auto) or let the clutch out slowly while holding the brake pedal hard. Give it a little bit of gas. If the air cleaner moves more then about an inch to one side, or you hear a thump under the floor near the tranny, check out your mounts. Mine did this too, and it turned out to be the drivers side mount.
It can also be a loose bearing holder on two piece driveshafts. The rubber eventually shrinks and breaks down, and the shaft can shake pretty bad. It could also be an engine problem, but not likely.
Old Oct 24, 2002 | 10:09 PM
orange peel's Avatar
orange peel
Jmarra
Oct 10, 2016 03:53 PM
jjreagan
2009 - 2014 F150
Jul 10, 2016 09:12 AM
MTNTIME
Dec 3, 2015 02:20 PM
jackdutch
Sep 23, 2012 01:21 PM
4CFarms
Aug 27, 2011 07:48 PM
