Acceleration is very choppy, need help
Old Aug 26, 2011 | 04:55 PM
4CFarms's Avatar
4CFarms
When i accelerate, it seems very choppy. Lkie i will be going 1000 rpm and it just jumps to like 1200 without any change in position from the pedal. It seems very weird and i cant figure it out. If anybody has any ideas then dont hesitate to share. The only thing i could think of its that i should run some cleaner through my injectors but thats it...
Thanks in advance, Luke
Old Aug 26, 2011 | 04:59 PM
bad12jr's Avatar
bad12jr
Check the pedal connectors. Clean it well with contact cleaner. Also dielectric grease them. Spray the throttle position sensor on it as well. More then likely has a little corrosion.
Old Aug 26, 2011 | 06:21 PM
Copedawg's Avatar
Copedawg
NO! no cleaner. Can you give any moe symptoms? Mods? miles? etc..
Old Aug 26, 2011 | 06:30 PM
Action4478's Avatar
Action4478
If the problem is consistent , you can test the TPS with a meter ..
You need to put a voltmeter across the GY/W and the GY/R wires on the connector to the TPS. With the key on, watch the voltage across the range of the throttle to see if there is any flat spots. You should see no less than .37 volts at idle position and no more than 4.5 volts at full throttle. The the third wire, (BRN/W), is the ref. voltage and should be 5 volts all the time.
Old Aug 26, 2011 | 07:49 PM
bad12jr's Avatar
bad12jr
Why no cleaner? Its just a potinetiometer
Old Aug 27, 2011 | 10:11 AM
makomark's Avatar
makomark
its not a 'classic' potentiometer but a modern (read that as economical to manufacture) printed circuit design. Anything "full strength" will eat into it I'm sure. I went thru the same irregular/irratic response and just replaced the APS...The dorman part is the one I opted for as the other aftermarket versions had fitment issues.
Old Aug 27, 2011 | 10:30 AM
Copedawg's Avatar
Copedawg
I have heard if you add to much fuel additive it can make it run rough or mess with the idle too. I wouldn't try to add any until the problem is figured out. (may add to the problem and diagnoses)
Old Aug 27, 2011 | 01:08 PM
bad12jr's Avatar
bad12jr
Oh got ya. Did not know that. Thanks because that would have been the first thing I would have done to mine
Old Aug 27, 2011 | 01:12 PM
Copedawg's Avatar
Copedawg
A mechanic at work told me (he is an "ex master mechanic" at Ford). He has been dead on with 95% of the stuff he told me.
Old Aug 27, 2011 | 01:16 PM
bad12jr's Avatar
bad12jr
The exact reason why I hang around on here. Woulda got jumped any where else.
Old Aug 27, 2011 | 01:36 PM
Copedawg's Avatar
Copedawg
SKIIIIRT! (sound of tires locked up at 55 MPH). Shame on me! I did not read what you wrote properly. I don't know why you can't try to clean the sensor.
I thought we were talking about adding fuel additive.
sorry.
Old Aug 27, 2011 | 07:48 PM
4CFarms's Avatar
4CFarms
thanks for all the help everyone, it turned out that it needed afuel filter very very very bad... It fixed it all up and she runs better than ever. but now having that said, i did want to clean out my injectors, anyone have any input on what kind of additive i should buy to clean them out?
DanielT28
Jun 13, 2013 09:51 AM
ewellman
Aug 25, 2004 01:59 AM
reamer
Jul 8, 2004 07:04 PM
SupaFord95
1978 - 1996 Big Bronco
Aug 20, 2003 01:28 PM
Redneckerson
Jul 8, 2002 08:59 PM
