Sponsored by: Real Truck
Check engine light on, and over-drive light flashing?
Old Apr 26, 2009 | 09:41 PM
gvsuman's Avatar
gvsuman
Hey guys, my check engine light came on a couple of days ago and the overdrive light started flashing. No hard shifts or any transmission issues. Ford dealer said it's time for a new VSS sensor on the rear diff. The past two days the check engine light has went off by itself and the OD light has not flashed either. Would this problem clear itself up, or change the sensor anyway? Thanks guys for any insight on this.
Old Apr 26, 2009 | 09:43 PM
JockD's Avatar
JockD
Do the speedometer and cruise control work properly?
Old Apr 27, 2009 | 05:03 PM
gvsuman's Avatar
gvsuman
Yes, there is no problem or any issue out of the ordinary. The check engine light was on and the OD light was flashing, but for the last 4 days or so the check engine light has not come back on and the OD seems to be working properly.
Old Apr 27, 2009 | 06:46 PM
12ozd's Avatar
12ozd
pull the vss from the diff. Clean / check , reinstall,should be good to go !!
Old Apr 27, 2009 | 07:31 PM
gvsuman's Avatar
gvsuman
If you take the VSS sensor off the rear diff, do you need to do anything with fluids or filters or anything like that?
Old Apr 27, 2009 | 07:51 PM
12ozd's Avatar
12ozd
Nope,pull it clean it, re-install it.
Old Apr 27, 2009 | 11:06 PM
gvsuman's Avatar
gvsuman
Hey thanks alot, I'll try that out. Catch ya later.
DirtMcGurt88
Oct 12, 2016 09:26 AM
mototrig
18
Mar 22, 2016 08:22 AM
gpacster
15
Aug 16, 2015 11:01 AM
MIKEBROUSSEAU
1997 - 2003 F150
Jan 1, 2015 02:05 PM
quarterhorseman
Oct 16, 2008 08:31 PM
