Dome light stays on.
Old Apr 26, 2009 | 05:38 PM
filipows's Avatar
filipows
I have an 06 Explorer Eddie Bauer. It has the overhead map/reading lights just above the mirror.
Yesterday I noticed that it/they were on all the time. The switches do nothing. This has nothing to do with the position of the dimmer that can be used to turn them on manually (light over rear seat is turned on then also).
It is just these two bulbs and they stay on after a start etc.
Yesterday I replaced the auto dim mirror. The harness for that was jostled in the process. I had the door open at the time and so the lights were on then. It was after that I noticed it was on all the time. I don't know if this was a coincidence or cause and affect.
Any clue on where to start and sort this out?
Thanks
Old Apr 26, 2009 | 08:17 PM
Old93junk's Avatar
Old93junk
Does your mirror have the "auto lamp" switch?.......Turn it all the way down.
Old Apr 27, 2009 | 08:29 AM
vicv's Avatar
vicv
Is the "door ajar" lamp lit up? Maybe the switch for the door latch is sticking.
Old Apr 27, 2009 | 08:35 AM
marragtop's Avatar
marragtop
When checking switches, don't forget the one on the rear gate.
Old Apr 27, 2009 | 08:21 PM
filipows's Avatar
filipows
Software error
Hello
Thanks for the good suggestions. It turned out to be a software" error"
I got the sequences on the switches goofed. I had the cover off and didn't realize the switch on the drivers side of the console controlled the light on the passenger side and vice versa.
Sorry for being sucha dufuss
But does anybody know how to negate the auto seat memmory???
I would like to kill that thing.
Old Apr 27, 2009 | 08:50 PM
marragtop's Avatar
marragtop
Maybe this helps...
Deactivating the memory seat feature
To deactivate this feature:
1. Press the SET control on the driver’s door panel.
2. Within 5 five seconds, press any control on the remote transmitter
which you would like to deactivate and then press the SET control on
the lower-center portion of the instrument panel.
3. Repeat this procedure for another remote transmitter if desired.
1. To disable/enable the easy exit
seat feature, select this function
from the SETUP MENU.
2. Press the RESET control to turn
the easy entry exit seat ON or OFF.
3. Press the RESET control for the
next SETUP MENU item or wait for
more than 4 seconds to return to
the INFO menu.
Reverse Sensing System (Park
pmoore96
Feb 27, 2017 12:38 PM
ford390gashog
2009 - 2014 F150
Apr 6, 2015 11:38 PM
Peter94
1983 - 2012 Ranger & B-Series
39
Dec 11, 2012 05:26 PM
elbatman22
1997 - 2003 F150
Oct 31, 2010 06:47 PM
