OK are you getting fuel out of the injectors. I'm assuming so.
Is your starter spinning fast these motors have to turn over pretty fast to fire.
Do not run your starter over 20 seconds then let it cool down for 2 minutes, these starter heat up fast and it will damage them if you stay on them tool long.
If you are spinning properly and getting fuel to the injectors the only thing left is the glow plugs are they working properly.
as long as the glow plug system is disbled starting fluid is fine, just use a little shot, we use it to crank my dads 7.3 every morning because the glows dont work, so i leave them unplugged just for saftey
