1979 - C6.. HELP !!!
Old Oct 27, 2002 | 09:36 PM
Schwee's Avatar
Schwee
Gents......
Put your transmisson hats on guys !
1979 4x4 f150.... frame rebuilt,,, reconditioned most everything over the last 9 months,,, except the trans as it was done 3 years ago and has about 10,000 miles.
i put an external fan driven cooler/filter on it,,, left the stock filter off.... also had to " home - weld " a transfer case frame mount....that summarizes my efforts to date,,, now....all of a sudden two "things" have started to happen...
1. when cold, it is slow to go into gear,,, forward or reverse....
2. form a standing start,,, when i moderatly "punch" the throttle, it more or less "pops" outta gear,,, this does not happen unless iam accelerating from a standing start.....
could it be .... vacum modulator or a band adjustment????
ne thoughts would be greatly appreciated ..
Schwee........
Old Oct 28, 2002 | 03:50 AM
78bronco's Avatar
78bronco
slow initial engagement based on my 78 book it says fluid level, linkage adjustment, clutch and band application, or oil control system
do you have to rev it up to get it to pop back into gear? if you do then its the fluid level most likely.
Old Oct 28, 2002 | 08:06 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Why? Did you just remove it? Is there a pickup so that you are sucking fluid from the bottom of the pan?
It sound like you are sucking more air than fluid at times. I think you need the stock filter.
Old Oct 28, 2002 | 09:28 AM
Schwee's Avatar
Schwee
>oil control system
Thanx......
hopefully i can just adjust the band....
Old Oct 28, 2002 | 11:16 AM
Schwee's Avatar
Schwee
>oil control system
As to "rev - up" question, the answere is no,,, i have to actual slow down or come to a complete stop.
thanx again for the help
Old Oct 28, 2002 | 03:26 PM
78bronco's Avatar
78bronco
i meant when you come to a complete stop, do you have to rev it up before it starts to move.
Old Oct 28, 2002 | 08:29 PM
Schwee's Avatar
Schwee
got it !!!!
replaced the modulator and was a little low on fluid
yeee haw
Old Oct 28, 2002 | 09:11 PM
kspilkinton's Avatar
kspilkinton
