Engine info
Old Apr 25, 2009 | 09:48 PM
ynkstr's Avatar
ynkstr
Engine info
Where exactly does a guy look on his engine, to find the numbers to check engine statistics?
I want to be sure of what I have for a motor and need some guidance.
(I was told it was a transplanted 390 V8 from a '66 thunderbird, but i guess ya never know for sure. I like it no matter what it is, but I'd be interested in finding out exactly.)
Thanks for any help!
~Bob
Old Apr 26, 2009 | 12:34 AM
85e150's Avatar
85e150
It is very hard to know for sure.
For the head casting number location, scroll down here:
ford head casting numbers,crankshaft casting numbers picture locations
Nice pic in that one, this has all the other locations for id info:
FE Engine Identification
Remember, just because the casting number might decode to a certain year and vehicle line, that does not mean it was origianally installed in that year or vehicle line. Casting numbers are pretty limited, but a casting code and date code will get you a little closer.
Check your PM also.
Old Apr 26, 2009 | 01:17 AM
65f100_352's Avatar
65f100_352
The best way is to measure the stroke. Get the motor to top dead center (TDC) and pull out the #1 spark plug. Insert a wooden dowel and make a mark. Then get the motor to bottom dead center (BDC) and make another mark on the dowel. Between the marks is you stroke. 3.5" = 352/360 roughly 3.75" = 390 roughly 4" = 410/428.
Old Apr 26, 2009 | 04:38 AM
jowilker's Avatar
jowilker
Bob, Without opening it up, there is no absolute way to tell for sure. The stroke measure along with some casting numbers can be a guide.
I believe if you do the TDC thing, passenger side front, you can can then go to passenger side rear and get the measurement for the stroke. I believe they are 180º opposed.
I prefer using a piece of 14ga. white house wire because it is smaller and the rubber covering slides easier.
John
Old Apr 26, 2009 | 06:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Since ALL 352/360/390/410/428 blocks were originally cast as 352's, any casting number you find won't tell you diddly-squat inre to what size the engine is.
Only when the blocks were finished...could they be another size.
Many of these blocks have 352 cast onto the drivers side of the block...that doesn't mean diddly-squat, either.
You cannot go by date codes, considering the date code only refers to the day the block was first cast.
It could be a year or more before a block found its way into a vehicle, considering that the foundry was in Dearborn, then the blocks after they were seasoned were then trucked to the engine plant.
After the engine was assembled, it was then shipped by rail to one of the dozens of assembly plants across the US, or to Oakville, Ontario Canada.
Bobmarlin
6.4L Power Stroke Diesel
13
Apr 23, 2007 10:12 AM
Mr. Bob
Jan 30, 2007 11:15 PM
bob_m10
1997 - 2003 F150
Feb 28, 2004 07:37 AM
yukonhighboy
1978 - 1996 Big Bronco
Nov 27, 2003 10:41 AM
unioncreek
Jan 2, 2002 12:07 PM
