49008 A/C Drive Belt Idler Pulley Tensioner Pulley
49219 Belt Tensioner Assembly
ooo thanks reps...i like not havin to track them down, it simplifies one tiny corner of my crazy life
got front tank sending unit part numbers handy, anyone? i'm really not anxious to repeat the running out of fuel experience...the gauge not working also just bugs me. lol
Originally Posted by joe_13894
Do you have the old tensioner or the OBS upgrade.
It's worth looking to the upgrade tensioner if you're replacing it. The original owner of my truck did it so I don't know how involved it is but I do know it helps with keeping the belt running tight.
i have idea...as near as i can tell no one really took super awesome care of her in the past, so i'm guessin it's old
Originally Posted by Talyn
Just fix it before I get there, So I'm not stuck helping you do it. =)
oh shush william, who says i'd let you mess with her anyways?!
so when i look on the motorcraft site...why are there like 3 different idler pulleys?! and of course the numbers are not the same and no prices...will napa have the goodyear parts?
If you have one tensioner pulley, you have the OBS tensioner. If there are two you have a superdoody tensioner.
I think you can just bolt the newer one in and put a longer belt on it. Someone who has done it would have to verify that though.
There are several advantages. The tension range is greater since it wraps the belt around two moving pulleys instead of one. There isn't a out of balance force that causes the tensioner to bend. This reduces the chance of the tensioner running out of true. The chances of breaking a tensioner bolt is less.
Originally Posted by BadDogPSD
Do you have a pic that you could post? Is a longer belt needed?
Here's the SD dual pulley tensioner:
And here's a lousy picture of it mounted:
Here's the TSB that shows how to modify the alternator bracket to make it fit:
Originally Posted by Welk49
what upgrade? Just went to the dealer and got both the new tensioner and a new idler pulley. Didn't know anything about an upgrade
Originally Posted by IDMooseMan
I'd like to know what upgrade is available, too. How do you tell if you have an "old" one or the "upgrade" one?
Well I have to say that my stock tensioner puller has a short arm and the new one has a larger arm, both with only one pulley, and the original belt was very tight to get in, but it does, I better bougth a larger one (about 2" IIRC) and fitted very well. I dont know if that can be considered like an upgrade
Same here. My 97 has a longer arm on the replacement tensioner. I've replaced one of the idler pulleys, but the other one I couldn't get loose. Is it possible that one of them has left handed threads?
Till I know the only with left handed threads is the pulley of the tensioner.
Looks like I have the "superdoody" upgrade. No wonder the belt was a PITA to install. I didn't know there were two different sizes. I'll hafta remember to ask for two "large" belts when I get ready to replace this one. Gotta have a spare of the right size.
