1952 Carburetor Problem:
Old Apr 24, 2009 | 09:47 PM
leonharu's Avatar
leonharu
When I back my truck out into the street and put on brakes to start forward the engine almost cuts off.The idle speed drops down real slow and then it comes back up to normal! What could be the problem? 1952 F-1 with flathead.
Old Apr 24, 2009 | 09:50 PM
bobj49f2's Avatar
bobj49f2
Sounds like it could be the pump inside the carb.
Old Apr 24, 2009 | 11:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Too high of fuel level, it's sloshing. Is your driveway pretty steep?
Old Apr 25, 2009 | 02:42 AM
Julies Cool F1's Avatar
Julies Cool F1
Park the truck in the other direction so you don't have to back out! See, no problem!
Well the Best of the Best have already answered this one.
But just to be contrary, how is your clutch? Does it tend to hang when there is reverse tension on the drive line?
Next time you back out try double clutching and see what happens.
Just thinking out loud!
Old Apr 25, 2009 | 05:14 AM
leonharu's Avatar
leonharu
Yes, it seems to be worse when I am on a incline or steep drive.It is one of them great rebuilt carbs from DC.I have noticed some sediment in my fuel pump bowl and I have never had an inline filter installed.Maybe something got to the carb? I did finally put a filter in the bowl today.
Old Apr 25, 2009 | 04:24 PM
Julies Cool F1
Yep - sounds like slosh over.
Hey Ross, will it do that when going around long turns too - like freeway off ramps, etc.
My Edelbrock does that - but it has the reputaion for it.
Old Apr 25, 2009 | 07:28 PM
leonharu's Avatar
leonharu
Now my idle speed is erratic!
Old Apr 25, 2009 | 10:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Check for vacuum leaks.
Julie, Does the Edelbrock have a side-hung float? The Holley 94 pivots in the front, so would not be affected by cornering so much.
Old Apr 26, 2009 | 03:00 PM
Julies Cool F1
Beats me! It came newly rebuilt from the factory so I didn't want to take it apart to look inside - it's a new model 750 cfm almost identical to a Carter. If it spits, I just open the throttle a dash and it goes away - fast!
ford0625
19
Jul 13, 2009 01:31 PM
hamz52
Jun 28, 2007 03:53 PM
91Bear
Mar 31, 2005 06:12 PM
fast68
Apr 10, 2004 03:34 PM
jrjrfm
Dec 31, 2000 10:48 AM
