Wiring Woes????
Old Apr 25, 2009 | 08:05 PM
RUSTY50F1's Avatar
RUSTY50F1
Wiring Woes????
I got tired of trying to use the wiring harness that came on the donor, so I ordered a ECM and wiring harness for the TPI 350. TO install it it says that I need to hook the hot to a 20 amp hot in run and and crank position. I am using a E-Z wire 22 kit. So does any one know which circuit I should hook it to. Thanks RUSTY
Old Apr 25, 2009 | 09:29 PM
49fordpickumup's Avatar
49fordpickumup
wiring
Depending on your steering column wiring. From you fuse box ( 20 amp or update fuse to 20 amp) thru the iginition (KEY) switch.Wires that come from the crank and run positions of your switch is usually in the column( Plug at the bottom of the column)(Darksider). Either use a meter to find wires or obtain a wiring diagram (colors)of the column wiring. ECM needs hot/ voltage for crank and in run positions. chuck
Old Apr 26, 2009 | 03:05 PM
Julies Cool F1's Avatar
Julies Cool F1
......Not gonna say a word!..........
